Sun Nov 27, 2016 4:34 pm
ryanbuckner offline
I deleted it and re-added it. It's being updated so I'm not sure why the sporadic errors.
Sun Nov 27, 2016 6:49 pm
Will check a little bit more in the next days. One explanation is the extra space. The variable looks identical you can see the blank. Had that before. Took me a long time to figure it out.
Sun Nov 27, 2016 10:15 pm
I looked at the logic:
it tries to update the variable. if it can not do that it will restart.
then at restart if will try to create that variable.
so if it works again after restart variable must be either unavailable or does not exist.
does not exist: something has deleted it.
can not update due to .?: could be that indigo is busy. That happens when an applescript runs and blocks indigo ( one of my favorite.) You will find that in the indigo or the general system log file as a timeout.
Tue Oct 10, 2017 7:43 pm
roquej offline
Karl,
Incorrect file attached to the latest version. It points to the uniFi plugin.
JP
Tue Oct 10, 2017 8:14 pm
sorry.. should be fixed now
