I have a suggestion. To get around having to put your password into the file, you can edit the /etc/sudoers file and allow Fing to run from sudo without a password prompt.
- Code: Select all
sudo visudo
add this line:
- Code: Select all
spanky localhost = NOPASSWD: /usr/bin/fing
That is, if "spanky" is your username (the one who will be executing the applescript and calling fing).
Note that this edits the file in "vi." Use the arrow keys or "j" or "k" to move up and down. Go to the line you want to add the above text and hit "i" for insert. Type or paste it out, then hit "esc." Then hit ":" then type "wq" for "write, then quit"
That should do it. It is important to use visudo to edit your sudoers file since apparently bad things can happen to the permissions of the file if you edit it directly. I just tested it on my Mac OS X Mountain Lion laptop. Works well. Everything else still needs a password for sudo, but not fing.
