Pi-Hole (ad blocking DNS server) Controller
Mon Jan 03, 2022 4:44 am
Re: Pi-Hole (ad blocking DNS server) Controller
Ah good, it is working for you then :?:
Sun Feb 06, 2022 8:43 pm
Ramias offline
Pi Hole devs have an open issue breaking the status ability of this plugin. Tracking here: https://github.com/pi-hole/AdminLTE/issues/2051. Workaround here: https://github.com/Ramias1/indigo-pi-hole/issues/2. though I think I'll wait for them to push a new pihole release and see if that fixes things.
Sat May 14, 2022 9:55 am
sumocomputers offline
I am on:
macOS 12.3.1
Indigo 2022.1
Pi-Hole Plugin v2.0.0
I am getting this error in the log repeatedly:
Pi Hole DNS Controller Error    Error in plugin execution runConcurrentThread:
  File "plugin.py", line 163, in runConcurrentThread
  File "plugin.py", line 140, in udpateStatus
type: local variable 'response' referenced before assignment
   Pi Hole DNS Controller Error    plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sat May 14, 2022 10:18 am
Double check that the IP address is set in the configuration of the Indigo Pi-Hole device.
The plugin is setting response only if the response is PiHole is Enabled or PiHole is Disabled, so in your case it must be something else, hence the suggestion to check the IP is set correctly.
Sat May 14, 2022 10:30 am
I checked the IP addresses and they are correct.
For fun I deleted the devices and re-added them, with the same errors.
I reverted to v1.1.0 and everything works again...
Sat May 14, 2022 10:33 am
It was worth a try.
Actually, I am also still on V1.1.0 which is working for me on Indigo 2022.1.0. :wink:
I'll await an update on the fix for V2 before upgrading.
Sat May 14, 2022 12:39 pm
Ramias offline
I will look at this today.
Sat May 14, 2022 2:01 pm
Ramias offline
This is working fine for me.
Do you have your Pi Hole running on a different port?
Do you have a password set?
what do you get when you run this from your terminal?
curl http://IP_ADDRESS_OF_PI_HOLE/admin/api.php
This issue has come up before: https://github.com/Ramias1/indigo-pi-hole/issues/2
This is my version of Pi Hole that is working:
Docker Tag 2022.04.3 Pi-hole v5.10 FTL v5.15 Web Interface v5.12
Sat May 14, 2022 2:25 pm
Not running on a different port, and I do have a password for the admin interface.
Reverting to v1.1.0 works for now.
Here is the curl output:
 {"domains_being_blocked":1115427,"dns_queries_today":40191,"ads_blocked_today":3903,"ads_percentage_today":9.711129,"unique_domains":7975,"queries_forwarded":32229,"queries_cached":3980,"clients_ever_seen":53,"unique_clients":40,"dns_queries_all_types":40191,"reply_UNKNOWN":368,"reply_NODATA":7209,"reply_NXDOMAIN":1415,"reply_CNAME":13667,"reply_IP":17260,"reply_DOMAIN":219,"reply_RRNAME":0,"reply_SERVFAIL":2,"reply_REFUSED":0,"reply_NOTIMP":0,"reply_OTHER":0,"reply_DNSSEC":0,"reply_NONE":0,"reply_BLOB":51,"dns_queries_all_replies":40191,"privacy_level":0,"status":"enabled","gravity_last_updated":{"file_exists":true,"absolute":1652007927,"relative":{"days":6,"hour
Sat May 14, 2022 2:49 pm
Ramias offline
Not sure what is going on. Maybe upgrade and turn on debugging and see what it shows?
Sat May 14, 2022 3:28 pm
Here is the debug output from v2.0.0:
   Pi Hole DNS Controller Debug    Starting concurrent thread
   Pi Hole DNS Controller Debug    Sent "PiHole Primary" status request
   Pi Hole DNS Controller Debug    data     <!doctype html>
    <html lang='en'>
        <head>
            <meta charset='utf-8'>
            <meta name="viewport" content="width=device-width, initial-scale=1">
            <title>● 192.168.2.15</title>
            <link rel='stylesheet' href='/pihole/blockingpage.css'>
            <link rel='shortcut icon' href='/admin/img/favicons/favicon.ico' type='image/x-icon'>
        </head>
        <body id='splashpage'>
            <div id="pihole_card">
              <img src='/admin/img/logo.svg' alt='Pi-hole logo' id="pihole_logo_splash" />
              <p>Pi-<strong>hole</strong>: Your black hole for Internet advertisements</p>
              <a href='/admin'>Did you mean to go to the admin panel?</a>
            </div>
        </body>
    </html>
Sat May 14, 2022 7:41 pm
Ramias offline
Ok just pushed 2.0.1 and tested with a password set. Take a look now. Thanks
Sat May 14, 2022 10:50 pm
2.0.1 works. Thank you so much!
Chris
Mon Dec 26, 2022 9:22 am
dherren offline
latest version returning an error
Greetings-
I had been using this excellent plugin for as long as I've had Pi-Hole running on my network. After the update to the latest version, I'm seeing the following errors and the plugin is no longer functional;
Dec 26, 2022 at 10:12:40 AM
Enabling plugin "Pi Hole DNS Controller 2.0.1" using API v3.0
Starting plugin "Pi Hole DNS Controller 2.0.1" (pid 66734)
Started plugin "Pi Hole DNS Controller 2.0.1"
Pi Hole DNS Controller Debug deviceStartComm: Pi-Hole Ad Blocking
Pi Hole DNS Controller Debug Sent "Pi-Hole Ad Blocking" status request
Pi Hole DNS Controller Debug Calling URL http://192.168.1.2/admin/api.php
Pi Hole DNS Controller Debug data []
File "plugin.py", line 164, in runConcurrentThread
File "plugin.py", line 141, in udpateStatus
Any suggestions for what I may have done wrong? Thanks!
Mon Dec 26, 2022 10:27 am
Same here with latest PiHole update
