reugster wrote:So how do you install it? Im at a loss
Hi reugster:
If you click on the download link, you'll go to the Github repository for the plugin. Look for a button that says "Download ZIP" on the right side of the page, near the middle. Click it, and you'll download the plugin archive.
On your computer, uncompress the zip file, and you should see a file named "Ecobee.indigoPlugin". If you double-click that, then Indigo should prompt you and ask if you want to install the plugin. Once you do, you will need to do some configuration; go to: Plugins -> Ecobee -> Configure...
Once that's done, you should be able to add your thermostat and/or remote sensor devices.
Good luck!
