Zigbee sensors
Wed Feb 12, 2020 5:02 pm
siclark offline
Zigbee sensors
An initial, I have done it post, with more detail to follow. Hopefully this is new and not redoing something else that has been done. But I was interested in getting generic zigbee sensors into Indigo that wouldnt sync via the Hue hub and the great Hue plugin (which I use for all my bulbs). I also didnt want to buy another hub.
Using a £10 USB stick (cheaper if you wait for Ali shipping) I have got a £10 temp/humidity/pressure sensor that looks great updating 3 linked devices in Indigo via MQTT. No other hardware required. This is opening up a new range of sensor options.
Wed Feb 12, 2020 5:15 pm
Re: Zigbee sensors
I thought you were also using an rPi?
Wed Feb 12, 2020 5:17 pm
siclark offline
Re: Zigbee sensors
Haha. I am but it’s not needed. You could run direct on a Mac mini. It was easier for me to setup on a pi than get a usb hub to fit the usb stick into my mini. Also it was already plugged into the pi to flash the firmware as I didn't bother buying the dedicated cable for it so used some jumper cables.
However who doesn’t have a spare pi or 2 lying around these days
Wed Feb 12, 2020 5:20 pm
Re: Zigbee sensors
I don't. I need to order some more. Had one die on me, and another is permanently attached to my Ender 3 printer, and another is moving to our storage facility to run the sensors there (relayed back to Indigo via MQTT). So the only one I have left is an old rPi 1, which isn't good for much. I've been buying 3B+ models. Maybe it's time to try out a 4.
Wed Feb 12, 2020 5:21 pm
siclark offline
Re: Zigbee sensors
Ah. I have 5 doing pibeacon duties one of which is also now running zigbee2mqtt in nodejs.
Wed Feb 12, 2020 8:10 pm
mundmc offline
Re: Zigbee sensors
This is great- please share any relevant deets on the plugins you used (eg Shims, MQTT, etc)!
Fri Feb 14, 2020 1:41 am
siclark offline
Re: Zigbee sensors
Will do. Just testing out a few setups and hardware. Really interested to read you can create a mesh of ZigBee USB sticks to work like zwave boosters.
Fri Feb 14, 2020 11:36 am
mundmc offline
Re: Zigbee sensors
Mesh??? Wow, that’s awesome
Fri Feb 14, 2020 11:47 am
siclark offline
Re: Zigbee sensors
Yes. If we just want it as a cheap sensor network and don't have mains wired devices to repeat like our zwave devices an extra $6 usb stick would solve that problem.
Getting another order in over the weekend to play some more.
Fri Feb 14, 2020 11:49 am
siclark offline
Re: Zigbee sensors
Just need to make sure with WiFi mesh around the house, plus Hue ZigBee light link plus ZigBee mesh, so 3 Networks all on same frequency that I manage the channels carefully.
Sat Feb 15, 2020 8:14 am
CliveS offline
Re: Zigbee sensors
All ready and waiting for the Zigbee writeup :)
CliveS
Sat Feb 15, 2020 8:31 am
siclark offline
Re: Zigbee sensors
Haha. Nice case. What sensor have you got?
I'll try and get onto it this evening. Just had a HDD in my NAS die so having to deal with that first.
Sat Feb 15, 2020 8:40 am
CliveS offline
Re: Zigbee sensors
At present only Philips Hue bulbs as most Aqara sellers are Chinese based so I am not ordering due to the delay
Case Stick and antenna preflashed for zigbee2mqqt for £22.00 first class royal mail delivery.
CliveS
Sat Feb 15, 2020 8:53 am
Re: Zigbee sensors
CliveS wrote:
... Case Stick and antenna preflashed for zigbee2mqqt for £22.00 first class royal mail delivery.
Is there a link for this? :)
Sat Feb 15, 2020 9:18 am
siclark offline
Re: Zigbee sensors
You can get aqara temp and humidity from Amazon in only 1-2 days and not much difference in price to the Chinese sellers.
Also look at banggood as they sell several sensor types shipping from Europe.
Users browsing this forum: No registered users and 19 guests
