Indigo / Node-Red / Alexa
Thu Feb 06, 2020 6:25 am
siclark offline
Re: Indigo / Node-Red / Alexa
Great. I created a speaker device yesterday that lets me say Alexa pause cable or Alexa pause Apple TV. And it sends right commands to the indigo action. Seems to be quicker than using routines.
I can also now mute the tv or change volume by asking for that. Not asking to turn off the volume. A bit more intuitive.
Thu Feb 06, 2020 6:53 am
MarcoGT offline
Great, very good news.
I am trying to the same setup on my dad's Indigo and I get an exception when opening the device details (after the double-click on the indigo-set-device).
getting devices
(node:13614) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'requestAsync' of undefined
    at /Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:128:31
    at Generator.next (<anonymous>)
    at /Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:7:71
    at new Promise (<anonymous>)
    at __awaiter (/Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:3:12)
    at Get (/Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:127:12)
    at Object.<anonymous> (/Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:43:22)
    at Object.GetDevices (/Users/domotica/.node-red/node_modules/indigodomo-node/dist/index.js:42:12)
    at /Users/domotica/.node-red/node_modules/node-red-contrib-indigo/77-indigo.js:149:14
    at Layer.handle [as handle_request] (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/layer.js:95:5)
    at next (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/route.js:137:13)
    at Route.dispatch (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/route.js:112:3)
(node:13614) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
(node:13614) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
^C6 Feb 13:47:58 - [info] Stopping flows
6 Feb 13:47:58 - [info] Stopped flows
Thu Feb 06, 2020 7:54 am
MarcoGT offline
And this happens when trying to load the devices defined in red-cb website
TypeError: RED.warn is not a function
    at /Users/domotica/.node-red/node_modules/node-red-contrib-alexa-smart-home/alexa.js:992:17
    at /usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:281:22
    at param (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:354:14)
    at param (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:365:14)
    at Function.process_params (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:410:3)
    at next (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:275:10)
    at expressInit (/usr/local/lib/node_modules/node-red/node_modules/express/lib/middleware/init.js:40:5)
    at trim_prefix (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:317:13)
    at /usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:284:7
    at Function.process_params (/usr/local/lib/node_modules/node-red/node_modules/express/lib/router/index.js:335:12)
Thu Feb 06, 2020 8:59 am
racarter offline
siclark wrote:
If you have a look at the documents on the site it shows you how to feed status back into the Alexa device to have it updated in the app. It’s not needed as Alexa will send the off command for instance even if she thinks the device is off.
However it’s certainly possible just a bit harder. You need to understand to format of the message to feed back, and I haven’t worked that out yet.
I use the iOS home app to see devices on my phone so don’t care what Alexa thinks the device state is as I never open the app other than testing.
For switches etc., try a function block with this code:
if (msg.payload_in == "ON") {
    return { "payload" : { "state" : { "power" : "ON" } }, "acknowledge" : true };
else if (msg.payload_in == "OFF") {
    return { "payload" : { "state" : { "power" : "OFF" } }, "acknowledge" : true };
Thu Feb 06, 2020 9:27 am
siclark offline
Cheers. Will have a play.
Thu Feb 06, 2020 4:31 pm
siclark offline
Sounds like an issue with the nose red install. Maybe try uninstalling and re installing?
Otherwise the dev has a slack channel and is pretty quick to respond. Think he’s on Europe hours.
Sat Feb 08, 2020 7:28 am
MarcoGT offline
After a uninstall and complete reinstall everything works fine, thanks :D
This is awesome, finally we have the control with Alexa; but, much more, it would be nice to be able to integrate Alexa devices directly in Indigo :mrgreen: :mrgreen: :lol: :lol: 8) 8)
Tue Feb 18, 2020 4:01 pm
siclark offline
Thanks to autolog I'm now trying to setup my own server on ECS to host the nodered alexa skill.
If I can get this working and the costs seem free/cheap I'll get the instructions up here.
Tue Feb 18, 2020 4:39 pm
Londonmark offline
Great. Hope you win.
Tue Feb 18, 2020 5:20 pm
siclark offline
2 hours in and thought I had made progress. I have a Ubuntu Vm running. Have cloudflare securing it but the nginx webserver doesn’t seem to work for me.
Thu Feb 20, 2020 1:52 am
MarcoGT offline
Just a quick question: I am super happy with node-red but this allows only to have in Alexa devices that are properly integrated in Indigo; the other way round is not possible, right?
Marco
Thu Feb 20, 2020 4:05 am
siclark offline
Do you mean read devices from Alexa that have been natively set up in Alexa, or not your dummy devices?
Thu Feb 20, 2020 5:17 am
MarcoGT offline
Yes, exactly; if I have a device that works only with Alexa, if I can control it in Indigo (I think this is what Matt/Jay are working on).
Thu Feb 20, 2020 5:22 am
siclark offline
I'm sure I saw a node-red node that lets you do that but can't find it now. I think that gets the device into node-red then you could use mqtt or the indigo nodes to get it into indigo.
Thu Feb 20, 2020 5:28 am
MarcoGT offline
That would be nice, if you can find it again :D
Page 4 of 11 1, 2, 3, 4, 5, 6, 7 ... 11
