Ethernet Relay Board -- Works Great!
Wed Sep 27, 2017 5:10 am
jens offline
Re: Ethernet Relay Board -- Works Great!
Is it possible to get an easier instruction how to make it work?
What code should you enter to activate a relay, eg nt 2 and how to turn it off again?
// Jens
Wed Sep 27, 2017 5:56 am
zaiks offline
jay (support) wrote:
How are you calling the script?
I'm callinng this as embedded script each call in separate Action Group
Unfortunately this is all I have
Wed Sep 27, 2017 9:27 am
And you just uncomment one of the lines at the top depending on what you want to do?
Wed Sep 27, 2017 2:40 pm
zaiks offline
Exactly
Thu Sep 28, 2017 2:48 am
zaiks offline
From an Indigo standpoint, you don't need to convert it since the script doesn't target Indigo.
Ok. This script might be converted to external and it does what it is supposed to do as long as Apple keeps it's scripting envionment alive.
But for status requests I call for Indigo and write the states to variables - this part will be killed as I understand?
Thu Sep 28, 2017 12:35 pm
I don't know - the code you posted doesn't appear to communicate with Indigo. To reinforce what we've already posted, any AppleScript that has a "tell 'IndigoServer'" in it won't work.
Sun Oct 01, 2017 12:53 pm
zaiks offline
Ok. Anyway as its always good idea to let something uncertain be the base for your crucial need I started to port this code over to python. I have all states read and written to variables, but for controlling I would like to get help with following shellscript:
curl --connect-timeout 2 --data saida1off=off http://admin:12345678@192.168.1.166/relay_en.cgi
How I can achieve the same with python?
Sun Oct 01, 2017 4:01 pm
See this thread: viewtopic.php?f=107&t=19059
Something like:
import requests
url = "http://admin:12345678@192.168.1.166/relay_en.cgi?saida1off=off"
r = requests.get(url)
# Example of logging to Indigo the HTTP result status code and text:
indigo.server.log("result status: %d, text: %s" % (r.status_code, r.text))
Mon Oct 02, 2017 3:17 am
zaiks offline
Thank you Joe - this pointed me to the desired direction :D
My code is maybe a little robust, but i'll share the results with you as well. Now I'm able to control this card with some different python scripts and am futureproof.
For statuses and writing these to variables:
 # Script for getting statuses of ethernet Relay board
import urllib
# Input your data here:
BoardIP = '192.168.1.166'
User = 'admin'
Pass = '12345678'
RelayName = 'No1' # If you have more than 1 relay board
# Constants and global variables
SearchString2 = "img src"
Result = ''
variableOut = ''
Output = ''
a = 1
# Start extraction of data
urlReturned = urllib.urlopen('http://' + User + ':' + Pass + '@' + BoardIP + '/relay_en.cgi')
data_getStatuses = urlReturned.read()
for a in range(1, 9):
   SearchString = 'saida' + str(a) + 'pluse'
   ResultA = data_getStatuses[data_getStatuses.find(SearchString):data_getStatuses.find(SearchString)+150]
   ResultB = ResultA[ResultA.find(SearchString2)+9:ResultA.find(SearchString2)+16]
   if ResultB == "lighton":
      Result = str(Result) + '1'
      Output = "true"
      Result = str(Result) + '0'
      Output = "false"
   # Sending info to variables
   variableOut = str(RelayName) + '_onStateRelay_' + str(a)
      var = indigo.variables[variableOut]
   except:
      indigo.variable.create(variableOut)
   indigo.variable.updateValue(variableOut, Output)
# Relay states as list
# indigo.server.log(str(Result))
For changing single relay state:
# Script for setting status of ethernet Relay board one relay at a time
import requests
User = 'admin'
Pass = '12345678'
RelayNo = '1'
RelayCommand = 'on'   # accepts on/off
key1 = ''
value1 = ''
# Start execution of change
url = ('http://' + BoardIP + '/relay_en.cgi')
key1 = 'saida' + RelayNo + RelayCommand
value1 = RelayCommand
payload = {key1: value1}
r = requests.post(url, auth=(User, Pass), data=payload)
For changing relay states by list:
# Script for setting status of ethernet Relay board relay's by list
import requests
User = 'admin'
Pass = '12345678'
RelayList = '00000000'  # 1- true, 0 - false, any other character - ignore, 1st relay is 1st position in list
key1 = ''
value1 = ''
a = 1
state = ''
RelayCommand = ''
for a in range(0,8):
   state = RelayList[a]
   if state == '1':
      RelayCommand = 'on'
   if state == '0':
      RelayCommand = 'off'
   if state <> '1' and state <> '0':
      RelayCommand = ''
   key1 = 'saida' + str(a+1) + RelayCommand
Sat Jan 13, 2018 11:02 am
jens offline
Where should I enter the code?
//Jens
Sun Jan 14, 2018 1:04 pm
TwitchCaptain offline
I just bought one of these network relay boards to control my four sprinkler zones and pool fill valve. I was trying to do this with an arduino connected to an 8 relay board, but what a mess. Once I write some code to interact with this board, I'll post it to my github. I'll aim for a plugin, but we'll see what I come up with. 8) Thanks for the data so far, this look promising!
Wed Jan 17, 2018 3:05 am
DomoPat offline
This relay board looks very interesting, what about the 8 inputs ? can you read their status or are they only able to command the relays ?
I have been looking for any sort of documentation about this board (and the inputs, as you seem to have the relay part well covered) and cannot find anything, do you have something ?
Thank you,
Patrick
Wed Jan 17, 2018 7:59 am
raneil offline
Thank you,
Patrick
Unfortunately there is no documentation provided, only scattered bits of information on the various eBay listings. But here's my best guess based on those listings and the onboard web-based UI. If I get a chance to test this out, I'll post an update.
    • The inputs are digital (presumably 5V), not analog.
    • Their current states cannot be queried like the relay states can.
    • They appear to be used only for directly controlling the relays.
    • There is a configuration webpage that can be used to map each input to any combination of relays. See screenshot below.
    • My assumption is that applying 5V to a given input will immediately energize the relay(s) mapped to it, and removing the input voltage will immediately de-energize the mapped relay(s).
Thu Jan 18, 2018 4:36 am
The input relays can be "disconnected" from the output relays and you can read their status remotely. Here's some docs to use TCP mode (not HTTP). This device is pretty epic, the only real disadvantage is that it must be polled. I'm working on a plugin now....
Parameters of controller Default IP: 192.168.1.166 Default TCP port: 1234
(1) Open the relay
TCP Relay Protocol V1.0
L(n) ,n=1:8,Such as the need to open the relay 1, then send the string “L1”. The board will return “Relayon 1” after the relay in operation.
(2) Close the relay
D(n),n=1:8,Such as the need to close the relay 1, then send the string “D3”. The board will return “Relayoff 3” after the relay in operation.
 (3) 800ms pluse,Open relay for 800ms,then close.
P(n),n=1:8,Such as the need to pluse the relay 1, then send the string “P1”. The board will return “Press 1” after the relay in operation.
(4) Read status of relays
R(n),n=1:8,Such as the need to read the status of relay 1, then send the string “R1”. The board will return “Relayon 1” or “Relayoff 1”.
(5) Read input status
I(n),n=1:8, Such as the need to read the status of input 1, then send the string “I1”. The board will return “IL 1” or “IH 1”.
(6) Burst mode read status
Send strings ”DUMP” or “dump”,the board will return all status of relays and inputs by end of “OK”.
(7) Examples
1. Connect to TCP port;
2. Send command,all commad by ends of “\r\n”;
3. If the PC within 30s no data is sent to the controller, the controller will disconnect to PC.
L1
Relayon 1
DUMP
Relayon 1
Relayoff 2
Relayoff 3
Relayoff 4
Relayoff 5
Relayoff 6
Relayoff 7
Relayoff 8
IL 1
IL 2
IL 3
IL 4
IL 5
IL 6
IL 7
IL 8
OK
To energize the input contacts, connect GRN to COM and 5V to one of the relay pins. There are two COM pins, one for ports 1-4 and one for ports 5-8. These can all be jumpered together if you're so inclined. The inputs are either on or off. (high/low)
Thu Jan 18, 2018 8:37 am
DomoPat offline
Very interesting, thank you Raneil and Frankyhall ! I am going to order one (or two considering the price !) to replace some old X10 modules and gain some inputs in a far away location. Nice !
