Holy moly! That's impressive, what on earth is all that stuff for?
Well, when we built a couple of years ago I ran ALL of the cabling and intelligence to the closet/rack in the office... and there was a LOT that I ran, in the multiple thousands of feet of cabling. Wife thought I was crazy, but what's new right?
Much of this is networking equipment - I work from a home office, so the equipment is somewhat doubled as I wanted to keep my work connection (which is a hardware VPN tunnel to the main office) separated from my home. No use in letting the network guys at work watch my Plex, am I right?
So, more-or-less top to bottom is:
- UPS bank (don't see it in the picture, it is on top of the rack... set of 5 UPS towers as it was cheaper than 2 big ones
- Shelf for cable modem and "external" switch
- Home networking - router / switch / patch panel
- Work networking - patch panel / switch / router
- Phone and video distribution (via Cat6) patch panels
- PoE injector
- HDMI-over-Cat6 modules (x2)
- HDMI selectors x2 (these select which signal goes to over the two distribution lines above)
- Video sources to be distributed - TiVo, Bluray, Roku, Chromecast, etc.
- Security DVR
- Audio distribution - amps and zone receivers
- Shelf for MacMini, hard drives, etc.
- Dell PowerEdge Servers scavenged from work... older but run Plex and network sniffer and monitors just fine!
Just ended up being able to put all things in one place, basically. The wires are a little messier than normal, at least on the side there, as I was doing some work on some things. The front patch panels won't ever look much cleaner than that due to the number of wires. Basically, every outlet near TV or office area or what not got Phone/IR cable, 2x Video Distributions cables, Coax Cable, Home Network & Work Network plugs. This is in a single gang box so isn't messy on wall, but all those cables come in to one spot so create quite a bundle. Overkill, I know, but I can hook up virtually anything in any room and the wife LOVES the distribution of video so that you can pause TiVo, walk to the other room and pick it up.
Adam
