jay (support) wrote:If you don't mind my asking, how did you get the listener working on port 80? macOS generally blocks any user apps from using protected ports (of which 80 is one).
Node-RED docs wrote:Amazon Echo Hub node is starting a service listening on port 80 which requires Node-Red process to be started with root user.
matt (support) wrote:Amazon Echo Hub node is starting a service listening on port 80 which requires Node-Red process to be started with root user.
so it looks like they get around the port 80 limitation by running it as root.
siclark wrote:Once deployed, I had to change teh Key from On/Off State to brightness to get it to show my a list of all the ItemNames.
Colly wrote:siclark wrote:Once deployed, I had to change teh Key from On/Off State to brightness to get it to show my a list of all the ItemNames.
I'm having the same issue and haven't managed to get it to show my list of items. Any suggestions?
