Alexa notifications via Notify Me Skill
Mon Apr 16, 2018 4:23 pm
whmoorejr offline
Found a fun Alexa Skill, Notify Me
https://www.amazon.com/Thomptronics-Notify-Me/dp/B07BB2FYFS/ref=sr_1_1?s=digital-skills&ie=UTF8&qid=1523917191&sr=1-1&keywords=notify+me
Lets you send notifications to your Alexa devices in various ways... http://www.thomptronics.com/notify-me
Took about 3 minutes to set it up, enable permissions in the Alexa app and get the email with an access code.
I'm using Python in action groups to send stuff... Alexa chimes and turns yellow about a second after the script runs.....
import json
import requests
body = json.dumps({
 "notification": "Hello World!",
 "accessCode": "ACCESS_CODE"
requests.post(url = "https://api.notifymyecho.com/v1/NotifyMe", data = body)
Bill
My Plugin: My People
Mon Apr 16, 2018 4:50 pm
Colly offline
Re: Alexa notifications via Notify Me Skill
Sounds interesting - can you select an individual Echo to play the announcement?
Mon Apr 16, 2018 4:53 pm
Nice find!
No - it uses Alexa's notification mechanism so all echos on the account will make the noise and flash the yellow LED.
Mon Apr 16, 2018 4:56 pm
Colly offline
Guess that rules out any late night notifications as the kids have an echo in their bedrooms. :(
Mon Apr 16, 2018 5:52 pm
ckeyes888 offline
Got the code and gave it a try but get this error.
Maybe I missed something?
Edit: Can the spoken text be directed to a variable?
Carl
Mon Apr 16, 2018 7:56 pm
whmoorejr offline
Carl
The "accessCode" is the whole string staring with "amzn1.ask.account.AH...blablablabla" Don't know if the space between the end of your access code and the endquote makes a difference. Did you enable the permissions within the Alexa app?
I'm sure, I can only copy/paste Python, but bringing in a variable shouldn't be to hard. That will be my next step as well.
In the Alexa app, Under Settings -> Select an Echo -> Sounds , you can disable the notification sound. I'm guessing the ring will still change to yellow, but it won't chime in their room.
Bill
Mon Apr 16, 2018 8:24 pm
ckeyes888 offline
Here's the code I'm using and yes I did enable permissions.
import json
import requests
body = json.dumps({
 "accessCode": "XXXXX"
It returns this in the log.
  embedded script, line 7, at top level
     File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/requests/api.py", line 111, in post
       return request('post', url, data=data, json=json, **kwargs)
     File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/requests/api.py", line 57, in request
       return session.request(method=method, url=url, **kwargs)
     File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/requests/sessions.py", line 477, in request
       resp = self.send(prep, **send_kwargs)
     File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/requests/sessions.py", line 587, in send
       r = adapter.send(request, **kwargs)
     File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/requests/adapters.py", line 491, in send
       raise SSLError(e, request=request)
SSLError: [Errno 1] _ssl.c:503: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Thanks for the help!
Carl
Tue Apr 17, 2018 7:27 am
whmoorejr offline
ckeyes888 wrote:
Here's the code
Carl.... I just ran your code on my end without error.
1) If you just got an Alexa notification that said "Carl, This is Bill"..... then it's not the code.... there is some kind of Python issue on your end.
2) Edit your previous post to remove your access code so I'm not tempted to send you random crap in the middle of the night.
3) I'm seriously Python handicapped.... so I can't help you troubleshoot that, but I'm sure someone else will chime in on that.... maybe a problem with your Kwargs? <- whatever that is?
Bill
Tue Apr 17, 2018 7:58 am
This looks like the SSL error on Sierra. Looks like Alexa has the same requirement as GitHub.
Tue Apr 17, 2018 8:44 am
I ran it on Sierra and it ran correctly. And it would be the api.notifymyecho.com host that would require TLS 1.2, not Amazon.
I think it's a Python version issue - Carl, what OS version are you running and what Python version? Open a terminal window and paste in this command and it will show you:
python --version
If it's earlier than 2.7.9, then that's the problem. Sierra & El Capitan have 2.7.10 (which works) so I'm guessing you're still running Yosemite or earlier, which have Python <=2.7.6 (which is the problem).
Tue Apr 17, 2018 4:18 pm
ckeyes888 offline
Here's the return:
TV:~ TV$ python --version
Python 2.7.2
I'm still on 10.8.5
Carl
Tue Apr 17, 2018 4:50 pm
ckeyes888 wrote:
Here's the return:
Python 2.7.2
Yep, that's the problem. Python 2.7.10 or later fixes an SSL issue that some sites trigger (apparently including the one needed for this script).
Tue Apr 17, 2018 8:33 pm
ckeyes888 offline
Thanks all. I’m moving to a mini running 10.12 which I’m hopeful will solve a number of issues I’ve been having.
Albeit...probably cause a bunch more. :cry:
Carl
Sat Apr 21, 2018 7:49 pm
ckeyes888 offline
Just upgraded to 10.12 and the script seems to run, causes my Echos to chime but doesn't speak the notification.
I'm using this script, (access code edited for posting).
import json
import requests
body = json.dumps({
 "accessCode": "amzn1.ask.account.AFGN3ZSDZXZ433ZNV3ORUEDZXKVD6KMKYT5H3LWBTUHQQYG7HNCV572GEV47RBCUGIWLOCA2ZFISZ5EWIAYZHPJ5POAWFSS7AV3LGGUB2VSEYACPTPBYIGPL4NMXB7SVC2A26ZXANCM6DO5YPSU6E6MIBMLWNSHNSOPJ4ZBX46BTILLOR4ZZXK5WZ7SEKHBXZTB5Q"
Any idea why it's not speaking?
Edit: Is it supposed to speak or just chime to let you know a notice just came in?
If it's just a chime I'm not sure what use it is.
Carl
Sun Apr 22, 2018 9:10 am
whmoorejr offline
Carl
Currently that is all it does. I talked to the developer of the skill and he said that the ability to “announce” isn’t covered in the skills API yet.
The workaround to integrate the “announce” feature is nothing less than ghetto-fabulous..... Place an echo device next to your Indigo server. Create an action that speaks, “Alexa, announce there is someone at the door”. Works pretty well with very short sentences without punctuation. (A comma in the sentence will sometimes cause her to send the message once there is a pause and ignore the second half of the sentence)
I’m using my ghetto setup more than the Notifyme thing at the moment. I’m using notifyme more for leaving little notes for my wife when I’m out of town.
For announcements, it will go to all devices unless you have switched the “do not disturb “ on through the app.
Anyways, my fingers are crossed that directly speaking (announce) will get incorporated into the skill.
Bill
