Reverse Reading of Fibaro Shutter FGR223
Forum rules
Tue Apr 23, 2024 2:59 am
joesan offline
I have 3 blinds installed in a row. Because of the physical setup, one blind is the opposite direction of the other two. As a result when they are in the open position, the Shutter Controller (Fibaro FGR223) shows as 0 for two of the blinds and 100 for the third one.
Is there a way to reverse the reading of that third controller so that it shows as 0 when in the open position (to match the other two blinds)?
Thu May 02, 2024 11:59 am
Re: Reverse Reading of Fibaro Shutter FGR223
Does Fibaro document any configuration parameters for that module that can flip the open/close direction?
Thu May 09, 2024 9:21 am
It does look like there’s parameters for exactly this situation:
