FGS-224 Double Smart Module - presume new Model ID
Forum rules
Fri Dec 09, 2022 9:42 pm
GlennNZ offline
Indigo Z-Wave Version: 2022.2.1
Node ID: 186
Model: Relay Power Switch
Model ID: 02043000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.08
Application Version: 5.00
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 27v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 98v1 9Fv1 5Bv1 60v4 70v1 56v1 71v1 75v1 7Av1 6Cv1 22v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01)
Multi-Endpoint Classes: 1:[5E 25 85 8E 59 75 71 6C 22 98 9F], 2:[5E 25 85 8E 59 75 6C 22 98 9F]
Features: routing, beaming, security
Neighbors: 2, 5, 7, 8, 9, 10, 16, 29, 31, 35, 36, 38, 39, 42, 43, 44, 46, 48, 51, 52, 55, 58, 59, 60, 72, 93, 94, 95, 100, 101, 102, 107, 108, 112, 139, 140, 149, 151, 152, 153, 158, 159, 160, 164, 175, 178, 179, 183
Associations: 1:[1] 2:[] 3:[]
& Oddly getting this logged everytime I turn on or turn off?
(that what my mistake - somehow I copied and paste the log entry into the name on a new line…)
ode ID: 186
Model ID: 02043000
Library Type: 3
Node ID: 186
Model ID: 02043000
Library Type: 3
Mobile Double Switch - 1" off
The logging was my mistake - must have copied and pasted the log details into the name field (who knew names could have multiple lines!)
Wed Dec 14, 2022 6:50 pm
Re: FGS-224 Double Smart Module - presume new Model ID
Yes, we'll have the new model ID added to the next release. Thanks for the report.
Wed Dec 14, 2022 8:27 pm
GlennNZ offline
Thanks Matt
Fri Feb 24, 2023 3:50 pm
We've added support for this new model ID in Indigo 2022.2.0, which is now available.
Fri Feb 24, 2023 4:38 pm
GlennNZ offline
Thanks - all going well!
