Zoos ZEN52 Double Relay and ZEN51 single relay.
Forum rules
Wed Dec 07, 2022 5:18 pm
hwitten offline
Zoos seem to make the smallest relays and since I have some switches I'd like to add relays to I thought I'd give this one a try.
Paired ok but basically works as one relay. Hopefully it'll be supported in a future release.
Let me know if any other info may be helpful. I'll run it as a single for now.
I also have a ZEN51, paired ok using "New with Encryption Disabled".
The ZEN52 I paired directly to the removed 'Stick' . Probably because it was my first try :wink:
ZEN52:
Indigo Z-Wave Version: 2022.2.1
Node ID: 113
Model: Relay Switch
Model ID: 01040202
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.15
Application Version: 1.30
Model Definition Version: 0
Library Type: 3
Class Name: Relay Switch
Class Hierarchy: 04 : 10 : 00
Command Class Base: 25
Command Versions: 20v1 25v1 5Ev1 55v1 9Fv1 6Cv1 70v1 85v1 59v1 8Ev1 86v1 72v1 5Av1 73v1 7Av1 60v4 22v1 5Bv1 87v1
Multi-Endpoint Types: 1:(10 : 00), 2:(10 : 00)
Multi-Endpoint Classes: 1:[5E 25 85 59 8E 6C 9F], 2:[5E 25 85 59 8E 6C 9F]
Features: routing, beaming
Neighbors: 3, 7, 12, 27, 29, 34, 36, 42, 47, 53, 66, 70, 77, 78, 84, 90, 91, 92, 94, 95, 103, 104, 105, 106, 108, 228, 230, 231, 232
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
ZEN51:
Node ID: 114
Model: Relay Switch
Model ID: 01040201
Manufacturer: Zooz
Library Type: 3
Command Versions: 20v1 25v1 5Ev1 55v1 9Fv1 6Cv1 70v1 85v1 59v1 8Ev1 86v1 72v1 5Av1 73v1 7Av1 22v1 5Bv1 87v1
Neighbors: 5, 7, 12, 25, 27, 29, 34, 36, 47, 53, 66, 70, 73, 77, 78, 83, 90, 91, 92, 94, 95, 100, 101, 104, 105, 106, 108, 228, 230, 231, 232
Fri Dec 09, 2022 3:18 pm
Re: Zoos ZEN52 Double Relay and ZEN51 single relay.
Thanks, we'll try to get definitions for these added to the next release.
Fri Feb 24, 2023 3:56 pm
We've added support for the Zooz Double Relay (ZEN52) and Dry Contact Relay (ZEN51) in Indigo 2022.2.0, which is now available.
