Page 2 of 2
Re: water tank level sensing
PostPosted: Mon Jun 20, 2022 2:35 am
by agame
just fyi I'm pleased to advise the 24volt pressure sensor spec sheet (according to google translate) confirms these are 24volt nominal, but gives a power supply range of 12-36v.
I ordered one from AU stock out of impatience, where i could only fine 24volt spec'd devices, a few more still on the way from China.
PostPosted: Sun Jul 24, 2022 3:02 am
by agame
just [hopefully!] closing off this thread: finally implemented GlennNZ's suggestion and working beautifully. fingers crossed!
I would caution anyone to expect loads of config issues in node-red and if all fails recreate a new indigo device once you are certain of the correct MQTT Shims config (this delayed me several hours!....but I cant recreate,...).
PostPosted: Sun Jul 24, 2022 8:12 pm
by GlennNZ
Hope it continues to go well.
Do you have any pointers/links for setting up node-Red/ESP32 and connection to sensor?. I may simplify and move in that direction down the track, or as a side project ( when need a side project!)
PostPosted: Sun Jul 24, 2022 11:05 pm
by agame
My flow is actually using pressure sensor> ADS115/i2c>RaspberryPi >Node-Red > MQTT > Indigo/MQTT/Shims....So no ESP/32s involved. (I thought you were also using this approach?).
The NCD ADS1115 sensors are hooked to RPis which are running node-red, and communicating with an mqtt server i have running on the Indigo mac (though of course this could be running anywhere - but i have it running for Shellies and a couple of other projects). Currently this is working on two different RPis, monitoring two and one tank respectively. One RPi is a 3 and one a Zero.
Using the NCD sensors makes this somewhat simpler as they have published node-red nodes for all their devices. These are available in the palette, however for some reason I had to uninstall and reinstall the NCD nodes via npm, and then do an npm rebuild before the ADS1115 would connect. I managed to connect with a generic ADS1115 node before getting the NCD nodes working.
The NCD node and hardware info is here:
https://flows.nodered.org/node/ncd-red-ads1115
Installing the NCD-red-ads1115 node is meant to automatically install a configuration node (NCD-red-comm) that handles the i2c communications. In my case this was not installing happily.
https://www.npmjs.com/package/ncd-red-comm
PostPosted: Mon Jul 25, 2022 2:35 am
by GlennNZ
I’m not completely loosing it - hopefully! - but sorry for confusing you.
Yes I use RPI and NCD ADS1115 with pressure sensor. I’m using pibeacon with sensor to read level.
Was thinking about simple=better and considering ESP32 devices (have setup a few lately with WLED and found it easy) with NodeRed. Your mention of nodeRED reminded me. Figured this might be simplest - forget that was my musing rather than what you had done….
PostPosted: Mon Jul 25, 2022 7:39 pm
by agame
ah! that makes more sense lol.
I haven't thus far played with a 'raw' ESP but I am increasingly impressed with MQTT - anything that builds on that architecture makes a lot of sense to me. And having MQTT Explorer for debugging is great.
And with RPis virtually unobtainable at the minute....
PostPosted: Tue Aug 30, 2022 1:08 am
by agame
in case anyone else is going down this track, especially if challenged by WIFI range, I just got one of these pressure sensors working on a Dragino LT Lora I/O controller. I'm getting at least 500m range through forest (supposedly 10km+ clear line of sight).
I'm running my own Chirpstack gateway on a RPi, however if you're in range of TTN or Helium, you don't even need that to get going. The devices are not much over US$50.
