Qubino Flush On/Off Thermostat 2
Forum rules
Sat Jun 05, 2021 5:46 am
patrikhson offline
I bought the Qubino Flush On/Off Thermostat 2 https://qubino.com/products/flush-on-off-thermostat-2-2/ after checking that it claimed it was supported on this page https://smarthomedirect.com.au/wp-content/uploads/2020/05/Qubino-Thermostat-2-Gateway-Compatibility-Matrix.pdf.
Anyone else using it?
After adding it, Indigo happily see the device but say it does not support it.
The log shows:
5 Jun 2021 at 13:38:18
Z-Wave received "Lada Kylskåp" mode is off
Z-Wave received "Lada Kylskåp" is idle
Z-Wave received "Lada Kylskåp" temperature update to 66.5 °F
Z-Wave received "Lada Kylskåp" units changed to °F
Z-Wave received "Lada Kylskåp" heat setpoint is 22.0 °C
Z-Wave received "Lada Kylskåp" units changed to °C
5 Jun 2021 at 13:43:21
Z-Wave received "Lada Kylskåp" temperature update to 19.2 °C
Z-Wave received "Lada Stallförråd" energy total to 26.06 kWh
Some things I can do with the device, but not really control it, and it definitely stays in some weird state. I am trying to use it for turning compressor on and off in a fridge, but it stays in off mode.
The device information is as follows:
5 Jun 2021 at 13:36:43
Z-Wave Indigo Device "Lada Kylskåp" Z-Wave Properties:
Indigo Z-Wave Version: 7.5.0
Node ID: 32
Model: General Thermostat (v2)
Model ID: 00050054
Manufacturer: Qubino
Manufacturer ID: 0159
Protocol Version: 6.09
Application Version: 21.00
Model Definition Version: 0
Library Type: 3
Class Name: General Thermostat (v2)
Class Hierarchy: 04 : 08 : 06
Command Class Base: 40
Command Versions: 20v1 40v1 42v1 43v1 85v1 86v1 31v7 6Cv1 32v4 70v1 71v1 72v1 73v1 55v1 59v1 5Av1 5Ev1 9Fv1
Features: routing, beaming, energyMeter
Neighbors: 2, 8, 11, 26
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
Sun Jun 06, 2021 12:17 pm
Re: Qubino Flush On/Off Thermostat 2
We haven't had any reports of users trying this one yet. Perhaps Qubino tested it themselves though. Based on the manual I would expect it to work even without an Indigo definition, so I'm not sure what is going wrong.
Note even without a device definition in Indigo you can use the Interfaces->Z-Wave->Modify Configuration Parameter... menu item to change the parameters mentioned in the manual.
What happens when you use Indigo to change the Mode between OFF and HEAT? With the default settings (based on the manual) I would expect those two modes to work. Once in HEAT mode you probably need to increase the HEAT SETPOINT in Indigo to be greater than the current temperature, then I think it should turn on.
Wed Jun 08, 2022 5:11 pm
7rdr7 offline
@patrikhson did you get the Qubino Flush On/Off Thermostat 2 working?
Tue Jan 24, 2023 11:27 am
joesan offline
I bought one of these, assuming that it would work with Indigo... Of course, now I realise it doesn't!
If I use the modify parameters command can I get this working ie controlling a load based on the temperature?
Tue Jan 24, 2023 3:35 pm
Can you re-sync it in Indigo then copy/paste the Event Log window results into a reply for me.
Also, how specifically is it not working? Does it not show as a thermostat device type?
Tue Jan 24, 2023 4:18 pm
joesan offline
Thank you for the quick reply Matt.
I was too quick off the mark. It actually seems to work quite well now! Just took a bit of time to establish comms.
I'm currently using it to control an electric radiant panel to touch-safe levels and it's reporting power levels reliably. In short, false alarm - it works great with Indigo!
Fri Jan 27, 2023 6:24 pm
Great, thanks for the update.
