NEST - updated plugin to support the new Google API
Forum rules
Wed Oct 21, 2020 10:37 am
bsp9493 offline
Not sure if this is the correct spot, but are there any plans to include/update an updated plugin for NEST?
Unfortunately for me, I had invested in nest, before google took over- 6 devices across 3 zones - so replacing my technology is not going to be cheap - my problem, not yours though:(
Having control of my thermostats and other NEST devices (ie scheduling temp changes based on time and home/away status or other dev ice status) was a very useful feature, which I have lost for quite some time now:(
One of the reasons I chose Indigo in the 1st place was it's vast support of current technology. Hopefully we can bring back an implementation of this plug in that works with the new Google API.
Thanx for your consideration.
dave
Wed Oct 21, 2020 2:23 pm
Re: NEST - updated plugin to support the new Google API
No idea if any of our current developers are using Nest products - I suspect any that were have moved on given Google's fickleness about 3rd party integration. It would need to be a plugin developed by someone else - there's just not enough demand vs everything else we have on our plates to do the integration ourselves.
[MODERATOR NOTE]: moved to a more appropriate forum
