Aeotec WallMote Quad 2W130
Forum rules
Sun Aug 02, 2020 2:19 pm
jalves offline
Just got this device and attempted to sync to Indigo. It appears to pair except for one error message in the log:
Aug 2, 2020 at 4:11:15 PM
   Z-Wave                          Syncing - started for "051 - WallMote Quad (ZW130)"
   Z-Wave                          Syncing - retrieved module neighbors list: 15, 22, 44
   Z-Wave                          Syncing - assigning return route to "051 - WallMote Quad (ZW130)"
   Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0086, WallMote Quad (ZW130) - 01020082
   Z-Wave                          Syncing - retrieved protocol version 4.62, app version 2.03
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 80v1 20v1 84v2 85v1 86v1 8Ev1 59v1 5Av1 5Bv1 5Ev1 60v4 70v1 71v1 72v1 73v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, waking
   Z-Wave                          Syncing - retrieved wake interval of 60 minutes
   Z-Wave                          Syncing - device "051 - WallMote Quad (ZW130)" wake interval changed to 60 minutes
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(18 : 01), 2:(18 : 01), 3:(18 : 01), 4:(18 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E], 2:[5E 85 59 8E], 3:[5E 85 59 8E], 4:[5E 85 59 8E]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave                          Syncing - retrieved group 6 associations: []
   Z-Wave                          Syncing - retrieved group 7 associations: []
   Z-Wave                          Syncing - retrieved group 8 associations: []
   Z-Wave                          Syncing - retrieved group 9 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved parameter 4 "Scene type" is 1
   Z-Wave                          Syncing - retrieved parameter 1 "Beep on touch" is true
   Z-Wave                          Syncing - retrieved parameter 2 "Vibrate on touch" is true
   Z-Wave                          Syncing - retrieved parameter 3 "Allow touch-drag up/down to brighten/dim direct associations" is true
Aug 2, 2020 at 4:11:41 PM
   Z-Wave                          Syncing - failed to retrieve parameter 5 "Touch LED color" (skipping)
   Z-Wave                          Syncing - retrieved battery level of 99%
Here is the device details from the log:
Aug 2, 2020 at 4:13:52 PM
   Z-Wave                          Indigo Device "051 - WallMote Quad (ZW130)" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 51
Model: WallMote Quad (ZW130)
Model ID: 01020082
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.62
Application Version: 2.03
Model Definition Version: 1
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 80v1 20v1 84v2 85v1 86v1 8Ev1 59v1 5Av1 5Bv1 5Ev1 60v4 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(18 : 01), 2:(18 : 01), 3:(18 : 01), 4:(18 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E], 2:[5E 85 59 8E], 3:[5E 85 59 8E], 4:[5E 85 59 8E]
Features: routing, battery, beaming, waking
Neighbors: 15, 22, 44
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[]
Config Values: 1:1 2:1 3:1 4:1
So, it appears that only the LED color remains undefined. The dialog box for the device configuration does have a line for Touch LED color, but the drop-down menu for that is dimmed out.
Jeff
Sun Aug 02, 2020 3:54 pm
Re: Aeotec WallMote Quad 2W130
It appears (based on multiple reports now) that Aeotec remove that configuration parameter from the firmware. We will be removing the UI from the next release of Indigo. You can just ignore the sync error and disabled UI for now.
