Vera Lite
Forum rules
Tue Mar 03, 2020 5:50 pm
jltnol offline
Vera Lite
So in my previous house, I had a door lock that was tied to a VeraLite, and from there via ethernet to Indigo. Honestly, I didn't know enough back then of how the lock was connected to the VeraLite, but now half way suspect it was via Z-Wave(though there may have been a unique protocol that the lock had that required the VeraLite) The Vera plugin worked just fine(after a lot of help and suggestions from the community). When I moved, I bought a Z-wave stick and never used the VeraLite. Everything else was Insteon. No Z-wave devices.
But I do have a detached garage with a few Z-Wave devices, and and ethernet connection back to the house. I'm wondering if its possible to pair the Z-Wave devices in the detached garage to the VeraLite, and thru the plugin, back to Indigo.
Tue Mar 03, 2020 8:21 pm
Re: Vera Lite
That is in fact probably the primary use-case for the Vera Plugin now that Indigo supports Z-Wave locks natively. It's an easy way to extend your control network to outbuildings and other things that are too far to reach via Insteon and/or native Z-Wave interfaces.
Wed Mar 04, 2020 9:16 am
jltnol offline
Re: Vera Lite
Great.
The ZWave connection out there works about 98% of the time, but good to know this is actually possible.
As always... THANKS!
