Forum rules
- Posted on
Sat Jan 18, 2020 11:25 pm
mediabox
offline
Anyone know if this will work? Seen the Quickset 9xx line and they are fugly. Kwikset 914 looks ok but not on the compatibility list.... The Schlage Z-Wave BE469 seems to have mixed issues with low battery life.
https://www.amazon.com/gp/product/B07BL ... GNHE&psc=1
- Posted on
Sun Jan 19, 2020 12:13 am
howartp
offline
Pretty sure Kwikset 914 is in use by some of my Zwave Lock Manager plugin users.
- Posted on
Sun Jan 19, 2020 9:29 am
jalves
offline
howartp wrote:Pretty sure Kwikset 914 is in use by some of my Zwave Lock Manager plugin users.
I've got the 912 and 916 and they both work just fine, so I'd be pretty sure that the 914 would also work.
Jeff
- Posted on
Sun Jan 26, 2020 10:38 pm
mediabox
offline
Bought the 914 but can't sync it. I've done the encryption option and tried factory resetting the Kwikset and excluded/included about 5x. Here's a trace. Any ideas? I'm syncing 5 feet away from my USB stick. Device isn't falling asleep because I can see the LED (on the Kwikset) flashing at certain points. In addition, I'll press a few buttons on it on a few rounds just in case. Thanks in advance. Will try to post in another thread that talks about this device.
- Code: Select all
2020-01-26 22:22:53.537 Z-Wave started controller inclusion mode with encryption
2020-01-26 22:22:53.539 Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
2020-01-26 22:23:00.729 Schedule Housekeep minutely
2020-01-26 22:23:00.729 Action Group update vars (landscape, deck status)
2020-01-26 22:23:00.730 Action Group set local time
2020-01-26 22:23:00.730 Action Group set uptime var
2020-01-26 22:23:00.730 Action Group update vars (motion_suppress/speak)
2020-01-26 22:23:00.730 Action Group update_device_vars
2020-01-26 22:23:00.731 Action Group Weather Update vars
2020-01-26 22:23:00.731 Schedule Housekeep minutely (light status only)
2020-01-26 22:23:00.833 update vars setting motion_suppress = false
2020-01-26 22:23:00.834 update vars setting motion_speak = true
2020-01-26 22:23:00.836 Script device: ('foyer_motion', {'dev_id': 1169251188, 'var_id': 993073399})
2020-01-26 22:23:00.841 Script Foyer - Motion last updated: 2020-01-26 10:21:31 PM
2020-01-26 22:23:00.842 Script device: ('Sump_pit_water_sens', {'dev_id': 1658471367, 'var_id': 1635282568})
2020-01-26 22:23:00.845 Script Sump Pump water sensor last updated: 2020-01-26 08:53:08 PM
2020-01-26 22:23:00.846 Script device: ('Aeotec_Multisensor6_Temp', {'dev_id': 1676315552, 'var_id': 517077869})
2020-01-26 22:23:00.849 Script Aeotec Multisensor6 - Temp last updated: 2020-01-26 10:12:59 PM
2020-01-26 22:23:00.849 Script device: ('smoke_detector', {'dev_id': 1043646669, 'var_id': 331256511})
2020-01-26 22:23:00.853 Script Smoke Alarm - Kitchen last updated: 2020-01-26 03:39:23 AM
2020-01-26 22:23:00.854 Script device: ('Ejector_pit_water_sens', {'dev_id': 1831175592, 'var_id': 622445004})
2020-01-26 22:23:00.857 Script Ejector Pit water sensor last updated: 2020-01-26 08:41:40 PM
2020-01-26 22:23:00.860 Script device: ('Noaa_dpa', {'noaa_wind_string': 364986697, 'dev_id': 1921154911, 'noaa_currentCondition': 1944536538, 'noaa_temperatureF': 1561501896})
2020-01-26 22:23:00.864 Script season = winter, too_windy = 25
2020-01-26 22:23:00.864 Script windString: West at 12.7 MPH (11 KT)
2020-01-26 22:23:00.865 Script wind_numbers: [12.7, 11.0]
2020-01-26 22:23:00.865 Script wind_speed_mph: 12.7
2020-01-26 22:23:00.886 Script too_windy = False
2020-01-26 22:23:02.439 Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
2020-01-26 22:23:02.440 Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
2020-01-26 22:23:02.440 Z-Wave stopping controller inclusion mode
2020-01-26 22:23:02.561 Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 00 00 B5
2020-01-26 22:23:02.562 Z-Wave stopped controller inclusion mode
2020-01-26 22:23:02.720 Z-Wave Syncing - started for "095 - Keypad Door Lock"
2020-01-26 22:23:02.745 Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 5F 01 01 26
2020-01-26 22:23:02.750 Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 02 30 0C 00 00 00 28 40 BC 45 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39
2020-01-26 22:23:02.751 Z-Wave Debug . . getNodeNeighbors: nodeId 095, neighbors: 2, 13, 14, 19, 20, 52, 54, 63, 67, 68, 69, 70, 72, 73, 75, 79, 84, 87, 88
2020-01-26 22:23:02.751 Z-Wave Syncing - retrieved module neighbors list: 2, 13, 14, 19, 20, 52, 54, 63, 67, 68, 69, 70, 72, 73, 75, 79, 84, 87, 88
2020-01-26 22:23:02.752 Z-Wave Syncing - assigning return route to "095 - Keypad Door Lock"
2020-01-26 22:23:02.752 Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 5F 01 E2
2020-01-26 22:23:02.763 Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
2020-01-26 22:23:04.318 syscall(/Users/xxxxxxx/Indigo_DB/get_video.py) returns: []
2020-01-26 22:23:04.318 compose_body():img_caps [u'cam_foyer2_20200126_222133.jpg', u'cam_foyer2_20200126_222139.jpg', u'cam_foyer_20200126_222133.jpg', u'cam_foyer_20200126_222139.jpg']
2020-01-26 22:23:04.318 stills: <a href="https://xxxxxxxxxxx.dyndns.org:1443/~xxxxxxx/indigo/cam_foyer2_20200126_222133.jpg"> cam_foyer2_20200126_222133.jpg</a><br><a href="https://xxxxxxxxxxx.dyndns.org:1443/~xxxxxxx/indigo/cam_foyer2_20200126_222139.jpg"> cam_foyer2_20200126_222139.jpg</a><br><a href="https://xxxxxxxxxxx.dyndns.org:1443/~xxxxxxx/indigo/cam_foyer_20200126_222133.jpg"> cam_foyer_20200126_222133.jpg</a><br><a href="https://xxxxxxxxxxx.dyndns.org:1443/~xxxxxxx/indigo/cam_foyer_20200126_222139.jpg"> cam_foyer_20200126_222139.jpg</a><br>
2020-01-26 22:23:04.319 vids: <a href="https://xxxxxxxxxxx.dyndns.org/webcam/None"> None</a><br><a href="https://xxxxxxxxxxx.dyndns.org/webcam/None"> None</a><br>
2020-01-26 22:23:05.215 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 48 0A 32 02 21 74 00 00 00 00 00 00 CC
2020-01-26 22:23:05.215 Z-Wave Debug . . requestMeterLevel: node 072, endpoint None, meterType 01, raw value 7400...
2020-01-26 22:23:05.216 Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
2020-01-26 22:23:05.445 Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
2020-01-26 22:23:05.446 Z-Wave Debug . . assignReturnRoute: node 095, success 1
2020-01-26 22:23:05.446 Z-Wave Syncing - assigned return route
2020-01-26 22:23:05.447 Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 5F 24 08 EA
2020-01-26 22:23:05.710 Z-Wave Debug RCVD nodeInfoFrame: 01 0E 00 49 84 5F 08 04 40 03 5E 72 5A 73 7A 53
2020-01-26 22:23:05.711 Z-Wave Debug . . nodeInfoFrame: node 095, combined class list: 20v1 73v1 62v1 63v1 5Av1 86v1 98v1 7Av1 72v1 5Ev1
2020-01-26 22:23:05.712 Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 5F 02 72 04 25 09 E2
2020-01-26 22:23:06.014 Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 5F 08 72 05 00 90 00 03 04 40 02
2020-01-26 22:23:06.014 Z-Wave Debug . . requestManufactureInfo: node 095, manufacturerId 0090, productId 00030440
2020-01-26 22:23:06.015 Z-Wave Debug . . requestManufactureInfo: Kwikset, Keypad Door Lock
2020-01-26 22:23:06.015 Z-Wave Syncing - retrieved manufacture and model names: Kwikset - 0090, Keypad Door Lock - 00030440
2020-01-26 22:23:06.016 Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 5F 02 86 11 25 0A 00
2020-01-26 22:23:08.124 sendmail() xxxx@xxxx.net
2020-01-26 22:23:12.401 Z-Wave Debug timeout waiting for reply from module (retrying)
2020-01-26 22:23:12.419 Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 5F 02 86 11 25 0B 01
2020-01-26 22:23:13.922 Alexa-Hue Bridge Set on state of device "Master Bed Lights" to ON
2020-01-26 22:23:14.438 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 54 0A 32 02 21 74 00 00 00 00 00 00 D0
2020-01-26 22:23:14.439 Z-Wave Debug . . requestMeterLevel: node 084, endpoint None, meterType 01, raw value 7400...
2020-01-26 22:23:14.439 Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
2020-01-26 22:23:20.057 Z-Wave Debug timeout waiting for reply from module (retrying)
2020-01-26 22:23:20.098 Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 5F 02 86 11 25 0C 06
2020-01-26 22:23:27.730 Z-Wave Debug timeout waiting for reply from module (retrying)
2020-01-26 22:23:27.735 Z-Wave Debug maximum retry count exceeded waiting reply from module
2020-01-26 22:23:27.735 Z-Wave Error Syncing - failed
2020-01-26 22:23:27.982 Z-Wave Error Timeout waiting for "095 - Keypad Door Lock". Module might be asleep, or is unreachable.
Jays-Indigo-mini:Indigo_DB jay$
- Posted on
Tue Jan 28, 2020 9:17 am
matt (support)
offline
- Site Admin
Here is
the duplicate post on the other thread. In the future please don't cross post. It makes tracking what are open/closed issues difficult.
