ANSWERED: Single Button Scene Controller
Posted: Mon Nov 18, 2019 4:03 pm
UPDATE: Got it working as required using Peter's (howartp) Z-Wave Scene Controller Plugin
I have a bought a single button scene controller.
I have included it successfully but cannot set up a trigger for a Device State Change. Only the battery Level shows as an option in the pulldown.
The manufacturer is shown as Monoprice but it is also marketed under the name Cyrus and Hank
http://manuals-backend.z-wave.info/make ... 0-16085175
Single Press:
Z-Wave received "Lichtschalter" scene 1 (0001)
Hold:
Z-Wave received "Lichtschalter" scene 513 (0201)
Release:
Z-Wave received "Lichtschalter" scene 257 (0101)
The battery status is also received frequently:
Z-Wave received "082 - Lichtschalter" status update battery level 100%
I was hoping to use raw packets, however there does not seem to be a fixed pattern to them
8.11.2019, 22:55:07
18.11.2019, 22:56:07
Z-Wave Z-Wave packets received during the last 60 seconds (oldest first):
59.8 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x18 0x00 0x01 0xE6
59.4 seconds ago from 082 - Lichtschalter:
0x01 0x09 0x00 0x04 0x00 0x52 0x03 0x80 0x03 0x64 0x44
58.6 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x19 0x00 0x01 0xE7
57.5 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x1A 0x00 0x01 0xE4
56.4 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x1B 0x00 0x01 0xE5
55.3 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x1C 0x00 0x01 0xE2
54.2 seconds ago from 082 - Lichtschalter:
0x01 0x0B 0x00 0x04 0x00 0x52 0x05 0x5B 0x03 0x1D 0x00 0x01 0xE3
It is a nice little button, rechargeable and relatively cheap. It would be great to get this integrated.
Tim
- Code: Select all
Z-Wave Indigo Device "Lichtschalter" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.0
Node ID: 82
Model: Basic Wall Controller
Model ID: 02000009
Manufacturer: MonoPrice
Manufacturer ID: 0208
Protocol Version: 4.34
Application Version: 1.03
Model Definition Version: 0
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 7Av1 5Bv1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 12, 13, 15, 25, 26, 28, 30, 35, 38, 47, 76, 77
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Single Press:
Hold:
Release:
8.11.2019, 22:55:07
Tim
