Supported Locks
Forum rules
Sat Jul 13, 2019 7:35 pm
Ericbo offline
Supported Locks
This is the only post available under locks ... so hope I am asking in the right place...
I am happy to say my standard front door lock died last week and I am looking at buying a smart/Indigo connected lock. Do you have recommendation out of all the models that can interface with Indigo?
Thank you very much :)
Sat Jul 13, 2019 7:40 pm
Re: INSTEON MorningLinc
Probably would have been better just to start a new thread. In any case, I've got two of the Kwikset 910 (Z-Wave) locks. Works just fine with Indigo.
https://www.amazon.com/gp/product/B004UHQHMO/
Sat Jul 13, 2019 10:36 pm
Dual offline
This one works well too:
Schlage Z-Wave Connect Camelot Touchscreen Deadbolt with Built-In Alarm, Satin Nickel, BE469 CAM 619, Works with Alexa via SmartThings, Wink or Iris https://www.amazon.com/dp/B00AGK9KOG/re ... kDbJFYXW2T
Sun Jul 14, 2019 9:45 am
Re: Supported Locks
Check the Locks section of the Compatible Devices list for a good start.
[MODERATOR NOTE] moved to a more appropriate forum.
Sun Aug 04, 2019 10:49 pm
ChopOMatic offline
Re: Supported Locks
This one works well with Indigo and I love it
https://amzn.to/2YHHVJe
Sun Sep 22, 2019 6:05 pm
Ericbo offline
Re: Supported Locks
Thank you all, looking at the 3 you proposed and will select soon !
Sun Sep 22, 2019 6:32 pm
nsheldon offline
Re: Supported Locks
I just installed a Kwikset 914 Z-Wave Plus keypad deadbolt and, while Indigo doesn't have a custom definition for this model, it does recognize it as a Kwikset keypad lock and seems to work just fine with it.
https://www.amazon.com/dp/B07DQC9FDG/re ... IDbK4RH8ZE
I use the Z-Wave Lock Manager plugin to manage user codes on the lock as well as detecting which user unlocks the door.
Fri Oct 04, 2019 10:43 am
bighop offline
Re: Supported Locks
I’m looking at the Kwikset 910 Zwave lock. Will that work with my current 2413U hub connected to my computer, or do I need another Hub so the Zwave product will be picked up by my server?
Fri Oct 04, 2019 10:46 am
Re: Supported Locks
The 2413U is an Insteon interface. You need a Z-wave interface for the locks. Like: https://www.amazon.com/Aeotec-Z-Stick-Z ... 00X0AWA6E/
Mon Oct 07, 2019 5:35 am
bighop offline
Re: Supported Locks
Thank you, I need to order that.
Will this lock show if the lock is open/closed? (Locked or unlocked?) I have an older lock, not sure of the brand name, but the battery’s die really quick. It didn’t connect to my server very well. Didn’t know if this version did any better.
Mon Oct 07, 2019 6:21 am
Re: Supported Locks
I have two of the Kwikset 910 locks. They work very well. If you use it mostly for monitoring, and don't open/close remotely much, the batteries last six months or more. Operating the lock off the batteries runs them down the most.
Mon Oct 07, 2019 7:18 am
bighop offline
Re: Supported Locks
Cool, can you see if the lock is open or closed?
Mon Oct 07, 2019 7:51 am
Re: Supported Locks
Yes, the Indigo UI shows that. And if you use the Z-wave Lock Manager plugin, you can see how it was last locked or unlocked, and also manage the PINs.
Mon Oct 07, 2019 10:07 am
Re: Supported Locks
+1. I've been using a 910 for about 7 years now (first through the Vera Bridge then directly). Some years ago, I accidentally dropped the battery cage (which is plastic) and it shattered. Contacted Kwikset and they sent me a new one for free within days - very impressed with their customer service.
Users browsing this forum: No registered users and 18 guests
