External temperature sensor
Forum rules
Mon Apr 22, 2019 11:44 am
peszko offline
Any recommendation for an external temperature sensor (z-wave). This is going to be used for things like pool water temperature, sauna, outside air temp etc... (range from -50 to plus 100) Yes, where I am it does go down to -30 with record at -39. So I need to run a sensor probe through a bit of a distance. Currently I use the insteon thermostat and re-wire the internal temperature sensor to use an external one. I find that the temperature is not reliable, not to mention that it rolls over when temperature is below zero and shows 127 (I have logic to account for that, butt... how on earth they made such basic mistake)
I was looking at : Qubino Z-Wave Plus On Off Thermostat Module ZMNHID3 with External Temperature Sensor but I don't see it on supported list for Indigo.
Mon Apr 22, 2019 9:29 pm
jltnol offline
Re: External temperature sensor
Let me know if you find a Z-Wave thermometer for your pool. I've been looking for a floating, waterproof battery operated Z-Wave thermometer for exactly this purpose.
Past that, I've got a Everspring ST814, and it does both temp and humidity, and it works fine. Not sure what the temp range is, I'm in Louisiana so we'd get close to 100ºF and down into the 20s, but again, not sure of the range.
Mon Apr 22, 2019 11:11 pm
you can try a platinum temp sensor(eg pt100 or pt1000). I tested the range: -45C to +400C(*) with cold spray and a flame
but you would need either a raspberry (pibeacon) or an ESP .. arduino chip to read them
(*) that should cover Louisiana
Sat Apr 27, 2019 3:57 pm
jasonstn_21 offline
Check out http://wirelesstag.net/
Not zwave, requires their tag manager (acts as a bridge)
I have 2 installed one for my pool and one for my hot tub.
Works great and the temp values can be pulled into indigo via ifttt
I was searching and searching and finally found this.
