POPP Flood Sensor
Forum rules
Mon Apr 08, 2019 4:08 am
bluefightingcat offline
POPP Flood Sensor
I just tried to add my new POPP Flood Sensor. I managed to sync it and add it as a device but when I add the sensor to water, the device does not turn on. This is the log of when I synced the device:
08 Apr 2019 12:58:41
   Z-Wave                          Syncing - started for "035 - Notification Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 1, 3, 4, 13, 23, 29
   Z-Wave                          Syncing - assigning return route to "035 - Notification Sensor"
   Z-Wave                          Syncing - assigned return route
   Z-Wave                          Syncing - retrieved manufacture and model names: Popp & Co. - 0154, Notification Sensor - 00040008
   Z-Wave                          Syncing - retrieved protocol version 4.38, app version 0.09
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, waking
   Z-Wave                          Syncing - retrieved wake interval of 1440 minutes
   Z-Wave                          Syncing - device "035 - Notification Sensor" wake interval changed to 1440 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - retrieved battery level of 100%
   Z-Wave                          Syncing - created device "035 - Notification Sensor"
   SQL Logger                      creating table device_history_934991737 for "035 - Notification Sensor"
   SQL Logger                      adding column "batterylevel" to table device_history_934991737 ("035 - Notification Sensor")
   SQL Logger                      adding column "batterylevel_ui" to table device_history_934991737 ("035 - Notification Sensor")
   Z-Wave                          Syncing - complete
   Z-Wave                          sent "035 - Notification Sensor" status request
   Z-Wave                          received "035 - Notification Sensor" status update battery level 100%/code]
The sensor clearly works otherwise because the siren goes off when I dip the sensor in water. But nothing happens in Indigo. Nothing in the log either.
The weirdest thing is that I have the exact same sensor made by Neo Coolcam. The physical sensor is exactly the same but it's branded as Neo coolcam. Also it appears that the firmware version is different. This is the log information I get when adding the Neo Coolcam version of the sensor:
[code]Syncing - started for "036 - Notification Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 1, 2, 4, 13, 23, 29
   Z-Wave                          Syncing - assigning return route to "036 - Notification Sensor"
   Z-Wave                          Syncing - retrieved manufacture and model names: Neo - 0258, Water Sensor (WS01Z) - 00031085
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 2.54
   Z-Wave                          Syncing - device "036 - Notification Sensor" wake interval changed to 1440 minutes
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - created device "036 - Water Sensor"
   SQL Logger                      creating table device_history_276753803 for "036 - Water Sensor"
   SQL Logger                      adding column "batterylevel" to table device_history_276753803 ("036 - Water Sensor")
   SQL Logger                      adding column "batterylevel_ui" to table device_history_276753803 ("036 - Water Sensor")
   Z-Wave                          received "036 - Water Sensor" status update battery level 100%
   Z-Wave                          received "036 - Water Sensor" status update is off
The website of the POPP version is here:
https://www.popp.eu/products/sensors/flood-sensor/
The webiste of the neocam one is here:
https://www.szneo.com/en/products/index.php?id=40
Sun May 12, 2019 4:32 pm
Re: POPP Flood Sensor
Indigo 7.3 (and 7.3.1) are now available and should support the POPP Flood Sensor (700052).
