Zooz ZSE18 Motion Sensor
PostPosted: Wed Jan 23, 2019 9:10 pm
by indigobo
Just got my hands on the Zooz ZSE18 Motion sensor. I have successfully added it to Indigo, but it doesn't it gives no notification of motion events. Has anyone successfully integrated this into their Indigo system?
Cheers! :D
Re: Zooz ZSE18 Motion Sensor
PostPosted: Wed Jan 23, 2019 9:42 pm
by matt (support)
Give the instructions here a try and I believe you'll be able to get it working using a couple of triggers.
PostPosted: Sun Mar 24, 2019 7:22 am
by Fluke
I purchased a Zooz ZSE29 outdoor motion sensor for turning on lights based on outdoor motion. Using the information from the provided link, I was able to get the desired basic functionality with little effort - thanks!
If anyone else is using this device, the command string I used to capture motion signal from the device was * 0x01 0x10 0x00 0x04 0x00 0x16 0x0A 0x71 0x05 0x00 0x00 0x00 0xFF 0x07 0x00 0x01 0x08 0x72 *, obtained from the device event log (converted to a compatible byte string) and inserted into the "match bytes" field of an event trigger that turns on lights based on the motion.
PostPosted: Sun May 12, 2019 4:10 pm
by matt (support)
Indigo 7.3 (and 7.3.1) are now available and should support the Zooz Outdoor Motion Sensor (ZSE29).
