Insteon Remote Control Dual On/Off Outlet #2663
Forum rules
Sat Apr 28, 2018 12:38 am
CraigM offline
Is anyone using this newer version of the old OutletLinc?
Can Indigo fully control both outlets yet? The bottom outlet used to be only controlled by extended INSTEON messages
If yes, are there 2 ID's or 1 ID like a FanLinc?
Can I assume the above answers are the same for the dimmer model?
Sat Apr 28, 2018 3:05 pm
billorav offline
Re: Insteon Remote Control Dual On/Off Outlet #2663
I have installed the Outletinc 2663 (non dimming) and it works fine in 7.1.
You can define both top and bottom to two separate - "new devices".
Also they are dual mesh, so it will improve insteon signal reliability vs. the older outlet.
Mon Apr 30, 2018 1:10 pm
CraigM offline
You say they are 2 devices, but are they 2 ID addresses? A FanLinc creates 2 devices, but only 1 address
Mon Apr 30, 2018 4:37 pm
2 Devices, but only one INSTEON address.
