Neo CoolCam Door/Window Sensor
Forum rules
Sun Jul 09, 2017 12:06 pm
CliveS offline
Re: Neo CoolCam Door/Window Sensor
bluefightingcat wrote:
Just tested this out. Works great so far.
I have just ordered two of these from Ali Express, seems a great price at £15.50 each (plus vat if they are stopped at customs) when compared to the £40 pounds plus for the Fibaro/Aeotec/Philio varieties.
Have you had any problems with them so far apart from Indigo support?
Has anyone tried the other Neo Coolcam devices yet like the NAS-PD01Z Z-wave PIR Motion Sensor, NAS-WS01Z Z wave Flood Water Leak Alarm Sensor and 1/2CH EU Wall Switch Sensor all around the £20 to £25 price range.
CliveS
CliveS
Indigo 7.1.1 : Mac mini Server (Mid 2011) : MacOS Sierra 10.12.6
Tue Oct 17, 2017 9:22 am
Lucardos offline
received today the Neo water sensor, WS01Z
unfortunately this does not work with indigo. Battery indication works, but the on/off does not.
here is the log of the water sensor " node 60" :
on:
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 3C 09 71 05 00 00 00 FF 05 02 00 4D
Z-Wave Debug . . requestAlarmSensorStatus: node 060, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 5, valueExt 2, classSubKeyExt 7100000502
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 3C 04 30 03 FF 06 03
Z-Wave Debug . . requestBinarySensorStatus: node 060, endpoint None, type 6, value 255
off:
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 3C 0A 71 05 00 00 00 FF 05 00 01 02 50
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 5, valueExt 0, classSubKeyExt 7100000500
Z-Wave Debug RCVD requestBinarySensorStatus: 01 0A 00 04 00 3C 04 30 03 00 06 FC
Z-Wave Debug . . requestBinarySensorStatus: node 060, endpoint None, type 6, value 0
battery level:
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 3C 02 84 07 4E
Z-Wave Debug . . nodeAwake: node 060
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 3C 02 80 02 25 07 7B
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 3C 03 80 03 64 2A
Z-Wave Debug . . requestBatteryLevel: node 060, level 100
Z-Wave received "060 - water sensor” status update battery level 100%
Tue Oct 17, 2017 10:00 am
CliveS offline
Click on 'Write Device Information to Event log' in the device config dialog and also the 'Define and Sync' and post them here.
Look at the beginning of this thread about either using raw commands to trigger your Neo Water Sensor before the profile is incorporated into Indigo ( I used them on the Neo Motion Sensor when I first got it without Indigo support)
jay (support) wrote:
You might be able to catch specific incoming messages from it using the Match Raw Packet message in the Incoming Command Received from Device Z-Wave trigger event.
or as I see 01 0F 00 04 00 3C 09 71 05 00 00 00 FF 05 02 00 4D so it may be possible to use the Zwave Lock Manager plugin
howartp wrote:
Just glancing at that log, you should be able to use my Zwave Lock Manager plugin to monitor that device.
71 05 alarm status commands are implemented so off top of my head it should work.
howartp wrote:
http://forums.indigodomo.com/viewtopic.php?f=210&t=17185&p=140487
Create a dummy door lock device (everything in this plugin is currently called a Lock even if it isn't!) and point it at your door/window sensor.
Create a trigger for your dummy lock with trigger event of ZWave Lock Manager Plugin > Door Opened.
Peter
CliveS (and welcome to the Neo club :) )
CliveS
Tue Oct 17, 2017 10:48 am
Lucardos offline
thanks CliveS
see below event log.
For me this is new ( always worked with compatible z-wave devices) and im struggling with the match Raw packet and door lock plugin.
will need some time to play with this.
Indigo Z-Wave Version: 2.0.68
Node ID: 60
Model: Notification Sensor
Model ID: 00031085
Manufacturer: Unknown
Manufacturer ID: 0258
Protocol Version: 4.05
Application Version: 2.54
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 4, 15, 16, 17, 24, 25, 27, 28, 50, 52
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
Z-Wave Syncing - started for "060 - water sensor"
Z-Wave Syncing - retrieved module neighbors list: 4, 15, 16, 17, 24, 25, 27, 28, 50, 52
Z-Wave Syncing - assigning return route to "060 - water sensor"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0258, Notification Sensor - 00031085
Z-Wave Syncing - retrieved protocol version 4.05, app version 2.54
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "060 - water sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Tue Oct 17, 2017 11:39 am
Lucardos offline
CliveS
thanks for your help.
It worked with the Match Raw packet.
hopefully Indigo will support all Noe products in the near future.
Lucardos
Tue Oct 17, 2017 12:19 pm
CliveS offline
Lucardos wrote:
CliveS
Lucardos
Great, well done, I also had trouble working out the Raw Packets initially but this forum does help so much.
We just need to sort out our problem with the EU plug power readout failing, I have been trying to find another home automation software that runs on either Windows or Pi that does not need a PhD in Nuclear Physics to install so I can try it out on another setup as the feedback from AliExpress says that the Power readings work with several other HA systems without error.
No luck so far and it makes me realise just how easy Indigo is to setup and run!
I will add the Water Sensor to it's own thread as it is lost in this thread at present.
CliveS
Tue Oct 17, 2017 12:46 pm
Can you link me to thread about EU plug Power readout?
Tue Oct 17, 2017 12:57 pm
CliveS offline
Certainly :) , I would love to get this working as Domoticz users say they have no problem yet I have 2 and @Lucardos has 1 and all 3 have the same problem of constantly resetting the power reading.
http://forums.indigodomo.com/viewtopic.php?f=58&t=19010&p=146281&hilit=neo+eu+power#p146281
CliveS
Thu Nov 09, 2017 11:21 am
Indigo 7.1.1 is now available for download and supports the Neo CoolCam door/window sensor.
