Zipabox Siren
Forum rules
Sun May 07, 2017 9:08 am
RedYuriPrime offline
Zipabox Siren
Having being looking for a while for a neat sounder that does both doorbell and alarm sounds, or indeed ANY device that is a decent z-wave doorbell sounder.
Just found the "ZipaBox Internal Siren" which appears just the ticket, :D
BUT:
Whilst it works perfectly with the ZipaBox controller it appears to be problematic with the Fibaro and other controllers. Can';t find any reference to it under Indigo. :(
I assume the problem is that there are configuration settings need to be changed to access the different sounds, but as a user you simply want to be able to use a normal commands to access any of the sounds.
So:
i) has anyone tried this device with Indigo7
ii) is there a way of changing configuration settings live within python programming rather than via the device settings dialogue (for any device, not just this one). Seems like a plug-in opportunity?
iii) does anyone know a better device for providing multiple audible outputs, each directly accessible from python code
Z-wave system with 80+ devices, Indigo7 on a dedicated MacMini
Controlling lighting, heating, hotwater, security; but still a lot to learn ... :shock:
Sun May 07, 2017 11:00 am
neilk offline
Re: Zipabox Siren
I have the D Link version which I think is the same and it works well using the raw Z Wave commands described http://www.vesternet.com/resources/appl ... s/apnt-125
Just use the send z wave commands action as shown below, no need to reconfigure or for a plugin.
It works fine, the siren is very loud, I use it as a doorbell triggered by my DoorBird.
Neil
Screen Shot 2017-05-07 at 18.04.42.png (59.55 KiB) Viewed 713 times
Mon May 08, 2017 1:03 am
Re: Zipabox Siren
Thanks Neil,
Will get one on order and post an update when its working ! :D
Geoff
Wed May 10, 2017 1:04 am
Re: Zipabox Siren
Worked well. Set up over breakfast - 15 mins despite distractions!
Tested Beep and Doorbell - my wife is still in bed so try the alarm sounds later :lol:
Thanks again, Neil.
Wed May 10, 2017 7:57 am
neilk offline
Re: Zipabox Siren
No worries - Glad it worked out.
Neil
