New Leviton Dimmer and Relay
Forum rules
Sat Feb 25, 2017 5:57 pm
jenwill1 offline
Full rocker now and changed that painful dimmer control.
https://store.leviton.com/collections/z ... 3943254083
Thu Mar 02, 2017 4:30 pm
jenwill1 offline
Re: New Leviton Dimmer and Relay
FYI
Received one from Amazon today. Syncs, on/off and dim work fine with Indigo 7.03. The rocker is a bit loose and stays in a neutral position except for the button press for on/off. Probably loose since this model also has the ability to change the rocker color with white/light almond. Vertical dimmer bar is much improved and doesn't require a fingernail to operate ! Dimmer indicator lights, emerald green, are on when the dimmer bar is activated but go off after a couple of seconds. A single LED at the bottom is illuminated when the light is off. All the LED indicator lights are hidden underneath the surface of the switch surround and are only visible when on. Very clean looking switch. Neutral required. Screw terminals. Sync was fast, < 2 secs.
Kudos for a clean looking switch with a much improved dimmer bar... if only the rocker was nice an tight on a button press.....
