Zipato Multisensor 4 in 1
Forum rules
Tue Jan 31, 2017 12:30 am
thomasw offline
Hi all,
I bought the Zipato Multisensor 4 in 1 which is Door/Window sensor, Humidity, Temperature, and Illuminace.
part# VS-ZD2201.US It is Z-wave Plus. It operates on 2 x AAA batteries.
It included in the Z-wave on Indigo with no problem, but shows up as "Routing Slave".
It displays battery percentage, but that is it, nothing else. When you open the configuration in Indigo, all you can
set is the polling reporting time, nothing else. (I'm using Indigo Pro V: 6.1.8 )
I need to use this to report the Humidity and Temperature in Indigo, I don't care about the door/window sensor or the Illuminace sensor.
Here is what shows up in the Indigo Event Log when adding the sensor:
Version: 1.0.363
Node ID: 16
Model: Routing Slave
Model ID: 201F1F10
Manufacturer: Vision / Yale
Manufacturer ID: 0109
Protocol Version: 4.05
Application Version: 6.01
Model Definition Version: 0
Library Type: 3
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 5, 11, 12, 15
Associations: 1:[1] 2:[]
Config Values: - none -
Is there a way to get the features of this sensor to work in Indigo?
This is a nice little multi sensor, well made, and the best part is it uses normal AAA batteries.
-Tom
Tue Jan 31, 2017 2:53 am
Re: Zipato Multisensor 4 in 1
I submitted the details for one of these months ago but nothing has happened with it! :(
Thu Feb 02, 2017 12:38 pm
Can either you enable Indigo's debug Z-Wave logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then trip the sensor 3 times (move magnet away and close), and also trip/reset the tamper switch 3 times?
Mon Feb 20, 2017 10:24 pm
thomasw offline
Hi Matt,
I did press write to log, but that only puts what I've already posted here in the Event Log.
Using the magnet 3 times doesn't put anything in the Event log at all? The tamper doesn't do anything either. (just blinks the little blue light) Only the battery status is showing in Indigo.
If you give me an address, I'll ship this sensor to you (through my email so you don't have to give it out on here) and you can figure it out for sure.
It would be great to be able to use this sensor in Indigo because it is so well made, and I love the built in features: Temp, Humidiy, door, illumanince, and it uses 2 normal AAA batteries!
Thu Feb 23, 2017 10:53 am
That is strange it isn't sending anything. It looks like it has 2 association groups. Indigo automatically added one for group #1 back to the Z-Stick. Try adding one for Group #2 back to the Z-Stick using the Interfaces->Z-Wave->Manage Associations... menu item. Note you'll need to wake the module for Indigo to be able to send the change to it. After you do that, re-sync the device (again waking it) – I want to make sure both associations "took.". Then try again moving the magnet to/from the module a few times with debug logging on. Copy/paste the Event Log results of all that into a reply for me and we'll see if it gives us any clues.
Sun Feb 26, 2017 11:35 pm
thomasw offline
Hi Matt,
I tried this again, and same thing. Nothing from the magnet open/close shows up in Event Log?
I deleted the device (016), and then added it again to the Z-Stick, then plugged back in Indigo.
It syncs immediately with the Z-Stick, and allows me to add the zipato device in Indigo, but
only the "routing slave" as 016. Nothing else but the battery status? No Temp, Humidity, etc.
I'm stumped.
Z-Wave Syncing - started for "016 - Routing Slave"
Z-Wave Syncing - retrieved module neighbors list: 1, 5, 11, 12, 15
Z-Wave Syncing - assigning return route to "016 - Routing Slave"
Z-Wave Syncing - retrieved manufacture and model names: Vision / Yale - 0109, Routing Slave - 201F1F10
Z-Wave Syncing - retrieved protocol version 4.05, app version 6.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "016 - Routing Slave" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "016 - Routing Slave"
Z-Wave Syncing - complete
Z-Wave received "016 - Routing Slave" status update battery level 100%
Feb 27, 2017 12:19:03 AM
Z-Wave Indigo Device "016 - Zipato" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.363
Node ID: 16
Model ID: 201F1F10
Library Type: 3
Associations: 1:[1] 2:[1]
Mon Feb 27, 2017 9:50 am
Are you sure you enabled the Z-Wave debug logging checkbox? I'm not seeing any logging above with the debugging prefix.
Sat Mar 04, 2017 9:25 pm
thomasw offline
Hi Matt,
I checked the debug box, and here is what is in the event log now:
Mar 4, 2017 10:19:39 PM
Z-Wave received "016 - Zipato" status update battery level 100%
Mar 4, 2017 10:20:16 PM
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 84 E2 4F 01 FF
Z-Wave Debug . . getHomeID: 25485903, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 08 F7
Z-Wave Debug . . getInterfaceFeatures: 08
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 10 12 13 14 15 16 17 18 1C 20 21 22 23 24 41 42 44 45 46 47 48 49 4A 4B 4D 50 51 52 53 54 55 56 57 5A 60 61 62 63 80 90
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 00 1D F3 FF 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 CC
Z-Wave Debug . . getInitialNodeData: [1, 2, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 92 16 00 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 20 01 5C
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Binary Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave found module included in controller with no matching device (missing or disabled): 002 - Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 03 EE
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Scene Switch (04 : 10 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27 2B 2C 72
Z-Wave Debug stopped polling of "005 - Dryer Buzzer LR- Levitron Appliance Switch"
Z-Wave Debug started polling of "005 - Dryer Buzzer LR- Levitron Appliance Switch" approx every 3600 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Binary Sensor (routing)
Z-Wave Debug . . postMultiInstanceUpdatedFunc: endpoint 001, classes [48]
Z-Wave Debug . . postMultiInstanceUpdatedFunc: endpoint 002, classes [49]
Z-Wave Debug . . postMultiInstanceUpdatedFunc: adding submodel to endpoint 002, model {'endpoint': 2, 'type': 'zwValueSensorType', 'name': 'Temperature 1', 'classSubKeys': [12545]}
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 20 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 10 00 04 00 0F 0A 32 02 21 12 00 00 00 1E 00 00 F3 (unsolicited2 -- requeuing)
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 008 - Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 08 06 F2
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: General Thermostat (v2)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 40
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 40 72 43 86
Z-Wave found module included in controller with no matching device (missing or disabled): 009 - General Thermostat (v2)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 12 96 00 01 01 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Portable Remote Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Relay Scene Switch
Z-Wave Debug stopped polling of "011 - Levitron Appliance Switch Fan-iMac 24"
Z-Wave Debug started polling of "011 - Levitron Appliance Switch Fan-iMac 24" approx every 300 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 05 E9
Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Relay Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 05)
Z-Wave Debug stopped polling of "012 - Siren Z-Wave"
Z-Wave Debug started polling of "012 - Siren Z-Wave" approx every 1800 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0D B7
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 13 96 01 01 01 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 013, class name: Portable Remote Controller
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0E B4
Z-Wave Debug . . getNodeProtocolInfo: node 014, class name: Portable Remote Controller
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0F B5
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 015, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug stopped polling of "015 - CatBox Light "
Z-Wave Debug started polling of "015 - CatBox Light " approx every 300 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 10 AA
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
Z-Wave Debug . . getNodeProtocolInfo: node 016, class name: Routing Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : -- : -- (04 : 07 : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 21 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Multilevel Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 31
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 31
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Relay Power Switch
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 0F 0A 32 02 21 12 00 00 00 1E 00 00 F3
Z-Wave Debug . . requestMeterLevel: node 015, endpoint None, meterType 01, raw value 1200...
Z-Wave Debug . . requestMeterLevel: 0 W (float: 0.000000)
Trigger Power Restored
Email Sent to .com"; subject "Power Restored"
Mar 4, 2017 10:20:37 PM
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 12 0A 32 02 21 12 00 00 00 1E 00 00 EE
Z-Wave Debug . . requestMeterLevel: node 018, endpoint None, meterType 01, raw value 1200...
Mar 4, 2017 10:21:07 PM
Mar 4, 2017 10:21:33 PM
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 10 06 31 05 01 42 07 CB 5A
Z-Wave Debug . . requestVarSensorStatus: node 016, endpoint None, type 1, raw value 4207...
Z-Wave Debug . . requestVarSensorStatus: 19.95 °C (float: 19.950000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 10 06 31 05 05 42 0A 74 EC
Z-Wave Debug . . requestVarSensorStatus: node 016, endpoint None, type 5, raw value 420A...
Z-Wave Debug . . requestVarSensorStatus: 26.76% (float: 26.760000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 10 06 31 05 03 42 0A F4 6A
Z-Wave Debug . . requestVarSensorStatus: node 016, endpoint None, type 3, raw value 420A...
Z-Wave Debug . . requestVarSensorStatus: 28.04% (float: 28.040000)
Wed Mar 08, 2017 5:58 pm
For the Event Log snippet above (after you enabled the debug checkbox), did you move the magnet to/from the module? I see broadcasts from the module for the temperature and humidity sensors, but not for the magnetic reed switch.
Regardless, here is a beta of Indigo's Z-Wave library that adds preliminary support for the Zipato Multisensor:
http://cloud.goprism.com/download/Z-Wave.zip
Re-sync it after you install it (extract it then double-click to install)), and Indigo should create the devices for all the sensors.
Thu Mar 16, 2017 1:29 pm
thomasw offline
Hi Matt,
Thanks, I'll get back to you later tonight, when I have a chance to install it.
-Tom
Thu Apr 27, 2017 9:02 pm
thomasw offline
Hi Matt,
I finally had time to try this. It didn't work.
I downloaded the beta and installed it. Then I shut down Indigo, rebooted, and re-synced the zipato.
I still only get the "Routing Slave" created. Just like before, the only thing it does is report the battery life
in percentage.
Just to be sure, I am running Indigo Pro 6.1.8. (can't install V: 7, due to the 10.7 or above requirement.
This machine is running 10.6.8 Snow Leopard.
Fri Apr 28, 2017 5:53 am
Sorry, I overlooked or forgot that in the original post you said you were using Indigo 6.1. The beta I posted only works with Indigo 7. Unfortunately, because this is a new device definition, and because how we store device definitions is completely different between Indigo 6 and Indigo 7, it will only be available in Indigo 7 and later.
Thu Nov 09, 2017 7:34 pm
Indigo 7.1.1 is now available for download and includes support for the Zipato Multi Sensor 4 in 1 (ZD2201).
