Trigger hs100 test
Script Error embedded script: global name 'requests' is not defined
embedded script, line 4, at top level
NameError: global name 'requests' is not defined
import json
import requests
# do the http request
reply = requests.get('python tplink_smartplug.py -t 10.0.0.26 -c info')
# convert the text result to Python dictionary
data = json.loads(result_json)
# extract the state
state = data['system']['get_sysinfo']['relay_state']
# update the variable (put in the correct variable ID)
indigo.variable.updateValue(1234567, value=state)
import requests
r = requests.get('python tplink_smartplug.py -t 10.0.0.26 -c info')
# get the results
data = r.json()
# extract the state
ChopOMatic wrote:No worries, Joe. Getting heavy-eyed here, too. Haven't been to bed yet. I appreciate the help a lot and we'll tackle it tomorrow if you're up for it. Again, thanks!
Script Error embedded script: HTTPConnectionPool(host='usr', port=80): Max retries exceeded with url: /bin/python%20tplink_smartplug.py%20-t%2010.0.0.26%20-c%20info (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x10ee54fd0>: Failed to establish a new connection: [Errno 8] nodename nor servname provided, or not known',))
import subprocess
import json
r =subprocess.call(['python', 'tplink_smartplug.py', '-t', '10.0.0.26', '-c', 'info'])
# get the results
data = json.loads(r)
# extract the state
ChopOMatic wrote:That doesn't work, either.
What would I add to the Python script and where in order to update the variable?
#!/bin/sh
python /Users/<you>/tplink_smartplug.py -t 10.0.0.26 -c info | grep relay_state | cut -c25
chmod 755 tplink.sh
