Nuki + bridge (doorlock)
Forum rules
Wed Sep 14, 2016 8:03 am
WouterK offline
Since doorlocks are supported by verabridge (and not having one anymore ;-)) I am looking for a european doorlock which will work with Indigo and fits my door.
Then I saw the Nuki + bridge doorlock solution ; https://nuki.io/en/smart-lock/
Is someone using this combination with Indigo already or can someone tell me if it should work with Indigo (the use of the bridge is necessary I think).
Thanks.
Regards,
Wouter
Wed Sep 14, 2016 8:35 am
RogueProeliator offline
Re: Nuki + bridge (doorlock)
Might have a look at some of the recent posts by the developers and just wait a tad bit longer...
http://forums.indigodomo.com/viewtopic.php?f=58&t=16526#p122220
That doesn't ensure your favorite lockset will be supported by Indigo directly of course, but certainly is a strong hint that at least something will be available in the not-too-distant future.
Adam
Thu Sep 15, 2016 2:49 pm
WouterK offline
Reading the post I will take your advise and wait a bit longer. Let's wait and see what the not-too-far future will bring :D
Thanks again.
Wouter
Sun Mar 19, 2017 1:26 pm
muxel offline
I use it with the bridge. I just send it a web command for locking, they have a great API. I think it would not be too hard to write a plugin, but it would be my first, so I'm not so sure if and when that will happen.
Mon Mar 20, 2017 11:52 am
WouterK offline
Great to read you are using one,. Since a couple of months I am using one, including a bridge, also.
I am using the callbackup function to get the actual status of the lock in indigo via a tiny webserver (python).
For now this is working great. Combined with the pibeacon plugin from Karl, I check if the door is closed when I am not at home; if not close it by the API command of the bridge ;-)
A plugin would be nice but, like you said, it would be a first for me..........
