Forum rules
- Posted on
Sat Feb 28, 2015 9:55 pm
costap
offline
I use Indigo at my current house in a almost exclusively Insteon setup. I am building a new house and am considering using Wink Relays as the Keypads instead of KeypadLincs. If I did this I would probably make my new house mostly Z-Wave. I know Indigo supports Z-Wave but as far as I can tell I will not be able to use Indigo if I use Wink Relay. Is there anything I can do to make the Wink Relay work as a keypad in Indigo?
- Posted on
Sun Mar 01, 2015 2:21 am
howartp
offline
According to the wink website, there is an API (
http://docs.wink.apiary.io/) but it doesn't look very well designed (possibly because the firmware behind Wink devices isn't very well written?) - someone who understands the Wink eco-system should be able to write a plugin to interact with Wink, though whether it has all the functionality you might want is anyone's guess.
- Posted on
Sun Mar 01, 2015 7:22 pm
jay (support)
offline
- Site Admin
[MODERATOR NOTE] moved to the appropriate forum.
