Controlling WEMO switch
Forum rules
Sat Feb 14, 2015 11:49 am
captcurrent offline
In my attempts to libe in a non standard world found a guide to a terminal script to control; wemo switch http://moderntoil.com/?p=839&cpage=1
Executing this script from an applescript has allowed me to integrate this I'm my Indigo setup where I cab't use the electric lines to transmit and receive
Mon Aug 10, 2015 5:05 am
Coolcaper offline
Re: Controlling WEMO switch
Thanks for the tip!
Wed Sep 23, 2015 2:21 pm
protean offline
I had some difficulty with the script mentioned on this thread, it later turned out it was my mistake, as usual. However, in the meantime I dug around and found a Python script that does a much simpler job of controlling Wemo devices from Indigo. I am guessing a much more savvy user than myself can script it using the Indigo built in Python script editor but for me, I use the Do shell Script with Applescript.
do shell script "wemo switch \"Kitchen Light\" on"
turns on the kitchen light.
The project website is here as well as a link to the complete documentation
https://pypi.python.org/pypi/ouimeaux
You will need command line developer tools (don't need Xcode, simply type git in the terminal and you will be prompted to download the command line tools). Once installed, Wemo devices can be used easily! No need for IFTTT.
Thu Nov 05, 2015 7:03 pm
ehuck offline
I'm having trouble installing ouimeaux. I did sudo easy_install ouimeaux. When I try to run the command wemo server it fails. Did I have to do anything else beforehand?
Fri Nov 20, 2015 10:36 am
protean offline
In Terminal, cd to the ouimeaux-n.n.n directory and try:
sudo ./setup.py
