Lock retrofit " Danalock" http://www.poly-control.com/
Forum rules
Sun Jul 12, 2015 1:05 am
Re: Lock retrofit " Danalock" http://www.poly-control.com/
I'm hoping Durosity caught my invisible wink and knows I was kidding in the friendly banter we've built up on here.
If you look at http://www.lockcity.co.uk/wp-content/up ... 0/mech.jpg that is an example of UPVC door locks in the UK. They make up probably 50% of all doors, the rest being traditional wood with lever locks.
http://dclocksmithsrhuddlan.co.uk/resou ... 00x500.jpg is a Euro lock that goes in the matching shaped hole in the lock - these are interchangeable in seconds, and a Zwave unit would equally well work.
However, look at the fierce looking hook. There are up to five of those up the length of the door edge, and sometimes top and rear-edge as well.
They are flush inside the door when the door is unlocked. When locking the door, you lift the handle upwards to engage all those hooks for additional security. The key lock won't turn until the hooks are fully engaged.
That's the problem we have - Zwave can't lift the handle to engage the hooks.
Sun Jul 12, 2015 2:11 am
I have seen very expensive motorised eurolocks before, about £500 or so.. But they need a wired 24v connection and of course a relay to activate.. Drilling for a cable width ways would be difficult and then you'd need a new hinge to run the wire through, plus there's no power on that side of the door in my house, so that'd involve serious replastering in an 18 month old house. Oh and of course I'd want a secure connection for it, I don't think a zwave relay would really suffice
Tue Sep 15, 2015 9:23 am
It's not BS3621 but this is an interesting:
https://www.locksonline.co.uk//acatalog ... -Lock.html
12v.. default position is locked.. allows for manual unlocking by just using the internal handle. Possibly powered by a PGM output on the alarm panel perhaps?
I wonder how much my insurance would go up by if my front door wasn't BS3621.
Tue Sep 15, 2015 11:31 am
I do like LocksOnline - their videos are very helpful.
Tue Sep 15, 2015 11:45 am
Very. As best I can tell that lock will also fit my door perfectly. Also as I'm going to have to knock big holes in the walls to rewrite my alarm system... So probably an opportune time to pre wire ready for such a system :D
Tue Sep 15, 2015 11:51 am
How are you thinking of using PGM?
Tue Sep 15, 2015 2:30 pm
Shutter offline
Thanks a bunch durosity, you just made me watch and 11 minute video on a door lock. Yes, yes, of course I want one now - it even beeps! Now way is this going to get by the other half. Nope, not at all. Oh well.
Tue Sep 15, 2015 2:55 pm
Lol!
Tue Sep 15, 2015 3:36 pm
I'm not sure actually, I'm just thinking that'd be a good way of being able to apply 12v to unlock in a secure way. I've not got much experience with PGM outputs beyond using it to trigger my garage door opener, but I figured it'd be a similar principle. Primarily I want to keep anything like this connected to a system that's 100% reliable and always online unlike my Mac mini. Oh wait neither is my alarm system since I knackered it at the weekend.
Tue Sep 15, 2015 3:37 pm
You're welcome. Try and convince her to buy one for me first so I can go through the suffering of "testing" it.
Tue Sep 15, 2015 11:43 pm
:-p
I'm not sure of your user-flow at the moment. PGM outputs (I think) need some sort of trigger - either alarm sounding (probably not when you want door to open!), a zone opening (ditto) or a code/tag being presented to keypad. Our keypad is in a cupboard slightly away from door, so wouldn't want to use that to open door.
The ACT10 keypads we've discussed elsewhere would work as an option.
Wed Sep 16, 2015 12:54 am
Ah well our keypad is right next to the front door, and yes it would need some kind of trigger like *72 on the keypad, but as the door auto unlocks when you use the internal handle and we keep the front door locked all the time anyway it would work perfectly for me. I could just have the unlock controlled via the virtual keypad and require a user code to enable it keeping it secure even if indigo was breached.
Wed Sep 16, 2015 12:58 am
And I suppose have some kind of programming that if zone 1 is open to not allow the lock to activate. It'd mean needing to still use a key to open the door unless using the virtual keypad but that isn't a huge issue. My primary want is the ability to check its locked and have it auto lock when the door is closed.
Fri May 27, 2016 10:41 am
mbrihed offline
Hi!
Are there any updates on support for the Danalock?
I have one and just started with Indigo and I would really like to add my Danalock.
/Mikael
