Required info to build support for new zwave device
Forum rules
Thu Feb 13, 2020 3:45 am
Stoutjesdijk offline
I have a few new-ish Heat.it devices that have only basic support (e.g. a dimmer). What information (about these devices should I provide so that the developers can build proper support?
Verzonden vanaf mijn iPhone met Tapatalk
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Thu Feb 13, 2020 4:22 am
Re: Required info to build support for new zwave device
The devices that I can provide information on are the Z-dim, Z-push and the (new) z-wave Thermostat.
Best regards,
Mark
Thu Feb 13, 2020 5:45 am
If you're able, select each device in turn and then select "Edit Device Settings...". Within the dialog box that appears should be a button that says, "Write Device Details to Event Log". Copy and paste the result and submit that data. You can add the information to this thread or submit via email.
Thu Feb 13, 2020 10:08 am
Do what Dave suggested but be sure and also submit them (from the settings dialog) back to our server so it gets added to our database. Also include the info Dave mentioned from the Event Log into a forum post and note which log snippet is for which device model. Lastly, copy/paste any links you have to PDFs of the manuals so we can see what configuration parameters they define.
Mon Feb 17, 2020 2:11 pm
HEAT.IT Pushbutton 4
(manual for 8-button: https://www.heatit.com/wp-content/uploa ... -A_ENG.pdf)
Z-Wave Indigo Device "1 slaap 4 buttons 2" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 30
Model: Basic Wall Controller
Model ID: 0300A306
Manufacturer: Sunricher / RGBgenie
Manufacturer ID: 0330
Protocol Version: 5.03
Application Version: 1.28
Model Definition Version: 0
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 55v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 6Cv1 70v1 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 2, 3, 5, 14, 17, 23, 24, 27
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Best regards,
Mark
Mon Feb 17, 2020 2:14 pm
HEAT.IT Z-DIM
(manual https://www.thermo-floor.no/media/multi ... -b_eng.pdf)
Z-Wave Indigo Device "bg keuken hoofdverlichting dimmer" Z-Wave Properties:
Node ID: 22
Model: Smart Plug (Z-Dim)
Model ID: 00032200
Manufacturer: HeatIT
Manufacturer ID: 019B
Application Version: 1.00
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 27v1 26v4 9Fv1 6Cv1 72v1 8Ev1 70v1 32v3 73v1 55v1 98v1 59v1 5Av1 5Bv1 7Av1 5Ev1 25v1
Features: routing, beaming, security, energyMeter
Neighbors: 3, 5, 14, 23, 24
Best regards,
Mark
Mon Feb 17, 2020 2:20 pm
HEAT.IT Thermostat
(manual https://www.thermo-floor.no/media/multi ... 2019-a.pdf)
Z-Wave Indigo Device "2 bad vloerverwarming thermostaat" Z-Wave Properties:
Node ID: 27
Model: Thermostat (TF021)
Model ID: 00010001
Protocol Version: 3.83
Application Version: 1.08
Model Definition Version: 1
Library Type: 6
Class Name: General Thermostat (v2)
Class Hierarchy: 04 : 08 : 06
Command Class Base: 40
Command Versions: 20v1 40v1 43v1 85v1 86v1 32v4 70v1 31v6 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, beaming, energyMeter
Neighbors: 2, 5, 14, 26
Best regards,
Mark
Mon Feb 17, 2020 2:22 pm
Hi Matt,
I do not have the option to submit the Z-Dim or the Thermostat; the button does not appear in the dialog.
Let me know if I can submit some other way.
Mark
Best regards,
Mark
Mon Feb 17, 2020 2:31 pm
We have stubs for a couple of those already so it doesn't show the UI to submit the details. Your Event Logs above will help.
How are all 3 modules behaving currently in Indigo? That is, what specific problems are you having with them (besides no configuration parameter UI showing)? For the 8 button controller we'll probably need to add the scene definitions so you can trigger off of all the button presses. Any other details on that one? And do the Z-DIM and Thermostat behave as expected?
Wed Feb 19, 2020 3:02 am
The dimmer and thermostat work as expected. The transmitter I have not tried yet. I will let you know what happens with short/long presses and releases etc.
Best regards,
Mark
Sat Feb 29, 2020 10:29 am
Hi again, and sorry for the delay.
I tried the pushbuttons, and although a z-wave message is sent when I press a button, I cannot seem to define a trigger with that message. It would be very useful if I could select "Button ** pressed short/long" in the Configure Incoming Command Received window.
I collected the following data from the buttons, hope they're useful:
Top “0” button
Z-Wave received "1 slaap 4 buttons 2" scene 4 (0004)
Top “1” button
Z-Wave received "1 slaap 4 buttons 2" scene 3 (0003)
Bottom “0” button
Z-Wave received "1 slaap 4 buttons 2" scene 2 (0002)
Bottom “1” button
Z-Wave received "1 slaap 4 buttons 2" scene 1 (0001)
Top “0” button long press
Z-Wave received "1 slaap 4 buttons 2" scene 516 (0204)
And release
Z-Wave received "1 slaap 4 buttons 2" scene 260 (0104)
Top “1” button long press
Z-Wave received "1 slaap 4 buttons 2" scene 515 (0203)
And release
Z-Wave received "1 slaap 4 buttons 2" scene 259 (0103)
Bottom “0” button long press
Z-Wave received "1 slaap 4 buttons 2" scene 514 (0202)
And release
Z-Wave received "1 slaap 4 buttons 2" scene 258 (0102)
Bottom “1” button long press
Z-Wave received "1 slaap 4 buttons 2" scene 513 (0201)
And release
Z-Wave received "1 slaap 4 buttons 2" scene 257 (0101)
Respective raw commands:
25.3 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x2E 0x80 0x04 0x19
23.9 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x2F 0x80 0x03 0x1F
22.3 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x30 0x80 0x02 0x01
20.0 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x31 0x80 0x01 0x03
18.4 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x32 0x82 0x04 0x07
17.6 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x33 0x81 0x04 0x05
15.9 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x34 0x82 0x03 0x06
14.6 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x35 0x81 0x03 0x04
12.8 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x36 0x82 0x02 0x05
11.6 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x37 0x81 0x02 0x07
9.8 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x38 0x82 0x01 0x08
8.3 seconds ago from 030 - 1 slaap 4 buttons 2:
0x01 0x0B 0x00 0x04 0x00 0x1E 0x05 0x5B 0x03 0x39 0x81 0x01 0x0A
Best regards,
Mark
Mon Mar 02, 2020 8:47 pm
We'll definitely add this to the list of device that need definitions. In the mean time, however, you can use the Z-Wave Scene Controller plugin to create Triggers when those scene commands are received.
Tue Mar 03, 2020 1:14 am
Just read the plugin forum thread first - the latest version appears to have a bug - the previous working version is discussed in the thread.
