Unable to open scripting shell from Indigo
Thu Sep 08, 2022 9:43 am
anyone offline
Just noticed this problem and I'm unclear if it's something I caused. The only recent change I made was moving my bash settings, configurations, and scripts over to zsh.
When I select Plugins -> Open Scripting Shell, I get a window displaying this:
/Applications/Indigo 2022.1.app/Contents/Resources/PlugIns/launch_indigopluginhost.command: line 5: /usr/local/indigo/indigo-host: Permission denied
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
the file launch_indigopluginhost.command contains:
#!/bin/bash
clear
looking at that path, the directory 'indigo' permission look odd.
drwxrwx---   7 root  wheel   224 Jul  2 10:00 indigo
I can however get to the shell with this;
'/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost' -i
What I can't do though is this, which is what I was actually am trying to do, is run code in this manner:
'/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost' -e 'indigo.server.log("hello")'
could not find/access plugin folder: /Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost.app/Contents/Resources/PlugIns/ScriptExecutor.indigoPlugin
Thu Sep 08, 2022 10:09 am
Re: Unable to open scripting shell from Indigo
Are you running from the account Indigo is installed under? If so, try rerunning the installer.
[EDIT] I think you are probably trying to run this from a non-admin account, which is the problem.
Thu Sep 08, 2022 10:59 am
anyone offline
Thanks for the assistance Jay. I'm running from an admin account, the same account Indigo was installed with.
I reran the installer, no difference.
What I tried after that was deleted the /usr/local/indigo directory, with the hope that the installer would replace it updating the permissions.
sudo rm -rf /usr/local/indigo
Then I re-ran the installer.
That resolved this issue for me.
