- Posted on
Sun Apr 17, 2022 10:50 am
daveHawk
offline
I just upgraded from 7.5 to 2021.2, and cannot upgrade any plugins on the new version. I get an error message as shown below. Consequently the following happens:
1) I get a popup "Server Connection Status" with the standard "Start Local Server" "Connect To Remote Server" options.
2) Clicking on the top portion of the popup, the Mac menu bar displays "Indigo 7.5".
3) Indigo 2021.2 is still running - Mac menu bar confirms this and the new Alexa builtin is shown as part of the plugin choices (I only mention this to confirm that 2021.2 is active).
4) Back to item 1), Server Connection Status: Choosing "Start Local Server" brings up dialogue for Starting/Stoping Local server - the only clickable option is Stop or Cancel - it is the dialouge/popuup for 2021.2.
5) At this point it is mess and I often have to individually kill Indigo processes.
I removed the 2021.2 version and invoked version 7.5; and upgraded some of the plugins within 7.5. I quit 7.5 and then reinstalled 2021.2. I then started 2021.2, and found that the plugins that I upgraded under 7.5, no longer showed that an upgrade was needed, and indeed they operated properly. However, I still had the same problem under 2021.2, in that I could not upgrade the remainig plugins! Does anyone have an idea as to how I can approach this?
Thanks in advance
MacOS Big Sur 11.6
Mac mini 2018 Intel
- Plugin Update Error.png (110.99 KiB) Viewed 1072 times
