IndigoServer produces excessive load
Thu Dec 16, 2021 4:37 am
Umtauscher offline
I have been searching for the a solution on my mac mini (2011) . The indigoserver task "out of the blue" suddenly had over 43 Threads and was consuming quite a lot of cpu.
Naturally I tried to disable all plugins but didn't find the cause of the problem for a long time.
Yesterday I found the cause: My ISP had changed the smtp port on their mailserver. That caused the whole problem.
After I changed indigo's smtp settings to the new port, 30 threads disappeared and the server load dripped to 10%.
Just to let you know, I'm happy again.
Cheers
Thu Dec 16, 2021 4:14 pm
Re: IndigoServer produces excessive load
Was this with Indigo 7 or Indigo 2021?
Fri Dec 17, 2021 12:47 am
Umtauscher offline
Indigo 7.5
Fri Dec 17, 2021 9:44 am
Email issues will have been significantly reduced in the 2021.1 release - we switched to a different email mechanism (a plugin) which is significantly more reliable.
Fri Dec 17, 2021 10:34 am
Umtauscher offline
Thanks, if it ain‘t broken, don‘t fix it.
I am happy with the performance now.
Until there is something I have to change, I will leave it running.
Cheers
Wilhelm
