2021.1 & Aeon Labs Garage Door Controller ZW062
Wed Oct 06, 2021 5:21 pm
anothersphere offline
My Aeon door controller ZW062 works perfectly well with 7.5, but with 2021..1.1 it does not.
It thinks it is open when it is not.
It does not respond to control.
Its an upgrade blocker for me presently.
See device dumps below.
Suggestions welcome.
Indigo Z-Wave Version: 2021.1.1
Node ID: 63
Model: Garage Door Controller (ZW062)
Model ID: 0203003E
Manufacturer: Aeon Labs7
Manufacturer ID: 0086
Protocol Version: 3.99
Application Version: 1.12
Model Definition Version: 3
Library Type: 3
Class Name: Secure Barrier Add-On
Class Hierarchy: 04 : 40 : 07
Command Class Base: 66
Command Versions: 20v1 25v1 66v1 70v1 71v1 72v1 73v1 5Ev1 98v1 59v1 7Av1 86v1 85v1
Features: routing, beaming, security
Neighbors: 1, 5, 6, 7, 8, 20, 23, 24, 25, 26, 27, 28, 30, 31, 32, 35, 37, 38, 39, 40, 42, 47, 48, 52, 53, 55, 57, 59, 60, 62
Associations: 1:[1] 2:[]
Config Values: 35:30 37:0 38:0 39:0 40:0 80:2 252:0
Indigo Z-Wave Version: 7.5.0
Node ID: 63
Model ID: 0203003E
Library Type: 3
Neighbors: 1, 5, 6, 7, 8, 16, 17, 20, 23, 24, 25, 26, 27, 28, 30, 31, 32, 35, 37, 38, 39, 40, 42, 47, 48, 52, 53, 55, 57, 59, 60, 62
Martin Miller
Auckland - New Zealand
Fri Oct 08, 2021 11:38 am
Re: 2021.1 & Aeon Labs Garage Door Controller ZW062
Can you turn on Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then try controlling the ZWE062 a few times? Copy/paste the Event Log window snippets of what Indigo sends/receives, and describe what actually occurs (if anything).
Wed Feb 09, 2022 12:55 am
Hmm, just tried 2021.2 and had a play and it is working now.
Probably a wet ware issue before. Must try harder!
I directly controlled the on/off and it seemed to then correct itself.
Martin Miller
