Indigo Server Question
Thu Jul 29, 2021 4:17 pm
jltnol offline
So I've noticed this a few times and am kind of confused. This is on my computer that is NOT running the Indigo Server, but on a computer running the Client. Not sure if this is normal, or if something might be wrong. This is Indigo 2021.1, but its possible this may have been happening previously.
Even when I quit the Indigo client, the server still shows up in the Activity Monitor. And although the process is in red, it continues to chew up CPU time.
Indigo isn't setup to automatically start on this computer, so I'm kind of at a loss as to what this process really is....
Screen Shot 2021-07-29 at 5.10.46 PM.png (106.18 KiB) Viewed 1163 times
Fri Jul 30, 2021 9:54 am
Re: Indigo Server Question
Looks like you installed the server on that Mac as well at some point and never uninstalled it. Probably an old version that's not compatible with the OS you're running.
Sat Jul 31, 2021 10:56 am
jltnol offline
Yep.
Got it fixed.
But just curious... how does one install the Client without the Server? Whenever a new version of the client is required, I just download the current installer and run it. It's very likely I've also started the server on this remote Mac for a test of something... but is it that once the server is started, it automatically runs on startup?
Sat Jul 31, 2021 12:29 pm
There is a Customize button in the installer from which you can then select to only install the client.
Mon Aug 02, 2021 11:08 am
jltnol offline
Didn't know/ Didn't see/ probably Didn't look, but very glad to know this now! Thanks!
