Lutron-controlled device throwing X10 J10 status request
Sun Jul 25, 2021 10:54 am
mundmc offline
By dumb luck, I figured out wherre my X10 "J10 status request" spamming error comes from: conces controlled by an on/off Lutron Caseta Pro switch!
Has this been encountered before? (I'll check with @FlyingDiver, who wroote the awesome plugin)
Thoughts on whether this is coming from LED sconces or the Lutron switch?
Any hacks that might address this short of replacing either part?
FWIW, this is not the only on/off Lutroin switch I use, and the others do not appear to throw this error.
Sun Jul 25, 2021 12:34 pm
Re: Lutron-controlled device throwing X10 J10 status request
My guess is it's the sconces making noise on the power line which is being interpreted as an X10 message.
Putting an X10 filter on that line, either before the switch or between the switch and the sconce, will probably fix it. No worries about it interfering with the Lutron switch - they don't use powerline signals at all.
joe
Sun Jul 25, 2021 12:35 pm
You could also try swapping the switch between locations to see if it stays with the sconce or moves with the switch...
Mon Jul 26, 2021 10:54 am
mundmc offline
My thanks as always!
