sql from integer to real
Mon Jan 04, 2021 11:48 am
I still get
   SQL Logger                      modifying column "pi_00_distance" type of table device_history_51480417 ("beacon-ble bug ") from integer to REAL
with state def:
         <State id="Pi_00_Distance">
         <ValueType>Float</ValueType>
         <TriggerLabel>Pi_00_Distance</TriggerLabel>
         <ControlPageLabel>Pi_00_Distance</ControlPageLabel>
         </State>
that should not happen anymore w indigo 7.5?
What am I doing wrong (lower case float) ?
Mon Jan 04, 2021 12:48 pm
Re: sql from integer to real
Is this for an existing device or a new one? The state info in the XML is only used when a device is newly created.
Mon Jan 04, 2021 3:48 pm
A new device
Mon Jan 04, 2021 4:32 pm
The case of "Float" doesn't matter. I tested it creating a new device then immediately dumped to the Event Log the states dict and it showed as a float. Is it possible your plugin is updating the state back to integer somewhere?
Mon Jan 04, 2021 5:01 pm
Converting back to int? How?
There is No xml stuff in plugin.py
Storing an int value would do it?
Mon Jan 04, 2021 6:19 pm
Yes, updating states is dynamic and will change the type based on the new value type passed in to the update call.
Mon Jan 04, 2021 7:16 pm
yes that was it: initialized with 99999 instead of 99999.
works fine now
thanks
