Are you in the
Edit Event Settings sub-dialog of the Trigger dialog? I just copy/pasted the lines you posted above into the Z-Wave Plugin and it worked, once I created a new Trigger in Indigo for a Trigger that has settings (Edit Event Settings button is visible and enabled in Trigger dialog):
- Code: Select all
Z-Wave Called getEventConfigUiValues(self, pluginProps:UiValuesDict : (dict), typeId:zwaveCommand, devId 0:
Z-Wave Called getEventConfigUiXml(self, typeId:zwaveCommand, devId:0, eventsTypeDict:Item : (dict)
zwaveCommand : (dict)
ConfigUIRawXml : <?xml version='1.0' encoding='UTF-8'?>
<ConfigUI><Field defaultValue="false" hidden="true" id="mode_matchBytes" type="checkbox" /><Field defaultValue="" hidden="true" id="description" readonly="true" type="textfield" /><Field id="targetDev" type="menu"><CallbackMethod>eventZWaveCommandReceivedUiChange</CallbackMethod><List class="self" method="getTriggerDevices" /><Label>From:</Label></Field><Field id="commandReceived" type="menu"><CallbackMethod>eventZWaveCommandReceivedUiChange</CallbackMethod><List class="self" dynamicReload="true" method="getTriggerCommands" /><Label>Received:</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" defaultValue="" id="matchBytes" type="textfield" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>Match bytes:</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="instructionsLabel1" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>Match bytes can use * to match 0 or more bytes, and ? to match exactly 1 byte.</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="instructionsLabel2" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>For example:</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="instructionsLabel3" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>* 0x7D ? 0x84 0x07 *</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="instructionsLabel4" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>would trigger on packet:</Label></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="instructionsLabel5" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>0x01 0x08 0x00 0x04 0x00 0x7D 0x02 0x84 0x07 0x0F</Label></Field><Field alwaysUseInDialogHeightCalc="true" id="logRecentPackets" type="button" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Title>Write Recent Packets to Log</Title><CallbackMethod>logRecentPackets</CallbackMethod></Field><Field alignWithControl="true" alwaysUseInDialogHeightCalc="true" fontColor="darkgray" fontSize="small" id="logLabel" type="label" visibleBindingId="mode_matchBytes" visibleBindingValue="true"><Label>This will write the last 60 seconds of incoming packets to the Event Log Window. You can then copy/paste the packet you want to match into Match Bytes above.</Label></Field></ConfigUI> (string)
Name : Incoming Command Received from Device (string)
SortOrder : 0 (integer):
