- Posted on
Tue Apr 28, 2020 12:08 pm
Gangotti
offline
Matt here is the information you requested:
From the Manage Links Window:
PowerLinc Linking - batch syncing changed links for "Marcus Keypad"
PowerLinc Linking - batch syncing changed links for "Living Room - Light"
PowerLinc Linking - batch syncing changed links for "Living Room- Fan"
PowerLinc Linking - batch sync started
PowerLinc Linking
PowerLinc Linking - syncing remote device "Marcus Keypad" (address 43.64.63, firmware version 45)
PowerLinc Linking - syncing changes only
Apr 28, 2020 at 10:56:02 AM
Error failed to fetch data from remote module
Error Linking - syncing of this device not possible remotely
Error Linking - syncing failed
PowerLinc Linking - device "Marcus Keypad" links updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Living Room - Light" (address 47.EE.23, firmware version 45)
PowerLinc Linking - insert memory address unknown; must perform full device sync
PowerLinc Linking - syncing all links
PowerLinc Linking - . . . read: INSTEON dev link to controller 31.18.82, flags AA, group FE, data 00 1C 00
Apr 28, 2020 at 10:56:41 AM
Received INSTEON "Laundry Light" on
Trigger Laundry Room Light Auto Off
Apr 28, 2020 at 10:57:01 AM
PowerLinc Linking - . . . read: INSTEON dev link to controller 43.A3.36, flags A2, group 01, data FF 1C 01
Apr 28, 2020 at 10:57:29 AM
Received INSTEON "Laundry Light" off
Apr 28, 2020 at 10:58:02 AM
PowerLinc Linking
PowerLinc Linking - syncing remote device "Living Room- Fan" (address 47.EE.23, firmware version 45)
PowerLinc Linking - syncing of this device not possible remotely (skipping)
PowerLinc Linking - sync complete
PowerLinc Linking - batch sync complete
From the Device Dialog Re-sync:
PowerLinc Linking - initializing remote device "Living Room - Light" (address 47.EE.23, firmware version 45)
PowerLinc Linking - initialize complete
Apr 28, 2020 at 11:00:40 AM
Error linking failed
PowerLinc Linking - syncing PowerLinc links (address 31.18.82)
PowerLinc Linking - . . adding: INSTEON plc link to controller 47.EE.23, flags 03, group 01, data 00 00 FF
PowerLinc Linking - PowerLinc links updated
Finally, the Re-sync did not help.
It seems to be failing to fetch data from the modules. These are new modules that have never been installed and purchased directly from the manufacturer. I would also point out that there are 2 modules with this issue, both from the manufacturer. One was installed under indigo 7-3, and the other under indigo 7-4
