Server frequently gets stuck in a high-CPU state
Tue Apr 07, 2020 3:22 pm
Chad_NE offline
Is debug-level logging possible?
Indigo Server gets stuck in this state every day with my fan screaming:
Although Indigo continues to function, the server must be killed and restarted. Only then does CPU usage return to normal.
Yet there is nothing suspicious in the log:
The only errors are due to disabled plugins. All were disabled to eliminate a likely source of issues:
The server and MacOS should be up to date:
BTW: Some amazing additions in this last, major release. Thank you!
Tue Apr 07, 2020 3:43 pm
RogueProeliator offline
Re: Server frequently gets stuck in a high-CPU state
One common cause of the server going to 100% is a device (or plugin, but you disabled most of them) which is updating the state of a device constantly... basically it just keeps slamming the server with device state updates multiple times per second. Notice any Last Updated dates of devices constantly updating?
Tue Apr 07, 2020 4:25 pm
Also, Indigo really don't like having the system go to sleep. You should have sleep disabled on your Indigo machine.
Tue Apr 07, 2020 5:08 pm
I agree with Joe – definitely get the Mac not trying to sleep first and see if that takes care of the problem. If it doesn't we can troubleshoot further.
Wed Apr 08, 2020 1:43 pm
Chad_NE offline
RogueProeliator and Joe. Thank you so much for your responses, and also for your contributions to the plug-in community. You make all of us better off.
Thank you also Matt!
You may all be well on the mark about sleep issues.
Indigo Server and client are on a personal MacBook Pro plugged into what amounts to a high-tech A/B switch. A work laptop is connected to the switch also. I can then choose which laptop works with a pair of monitors. Both laptops are closed up ("clam-shell" mode).
To prevent sleep when switching, I use Amphetamine:
https://apps.apple.com/us/app/amphetami ... 4704?mt=12
I see that I failed to restart Amphetamine following a reboot! Let me reboot again, correct my error and see if the problem persists. I will get back with an answer either way.
Appreciatively,
-- Chad
Thu Apr 09, 2020 1:06 pm
Chad_NE offline
The machine has been kept awake, yet I see the same high CPU usage today. Please let me know if there might be some advanced logging I can use to gain insight.
Thu Apr 09, 2020 2:25 pm
Indigo utilities plugin has a cpu logging feature- you could try that.
Will give cpu/100 secs for all
Plugins, client and server.
Fri Apr 10, 2020 5:52 pm
Chad_NE offline
Karl,
Thank you for your help. I can see how much effort has gone into this plugin! This will be a powerful weapon in my hunt for the problem.
I found yet another way to sabotage myself... anti-virus software:
Doh! Hopefully once I eliminate all these issues the problem will disappear.
Thanks again!
Fri Apr 17, 2020 4:38 pm
Chad_NE offline
It's been a week, and there has been no recurrance of the high-CPU issue, even with all necessary plug-ins enabled.
It looks like I've identified to ways to sabotage yourself:
- Allowing your machine to sleep
- Thwarting Indigo server's disk access with anti-virus software
Perhaps this will help someone else in the same boat.
Thank you all for your responses, insight and support!
