I assume it does because a user has reported a problem in the Alexa-Hue Bridge plugin which was due to having an umlaut in a variable name.
However, I have tried to create one and Indigo won't let me do this via the UI. I tried a copy and paste (or tried to ) of a name with an umlaut. The paste was ignored. Pasting a non-umlauted name works OK.
So I used a script to set a name:
- Code: Select all
>>> newVar = indigo.variable.create("OütputT", "true")
- Code: Select all
>>> newVar
<indigo.Variable object at 0x113427b18>
>>> newVar.value
u'true'
>>> newVar.name
u'O\xfctputT'
If I select a standard named variable I get the Duplicate and Delete... buttons.
If no variable is selected the New... button won't display.
Is this a bug or have I done something wrong?
