Regularly seeing in the log:
" Connection in Line '3526' has error=''key ip5 not found in dict'' "
How to understand where the problem is? What does it mean the "Connection" component?
for i in range(len(self.ipNumbersOfAPs)):
if not self.isValidIP(self.pluginPrefs[u"ip"+unicode(i)]): # <--> this must be it. completely different line though
_GlobalConst_numberOfAP = 5
self.ipNumbersOfAPs = ["" for nn in range(_GlobalConst_numberOfAP)] # .. it goes from 0..4
23:19:42 -
23:19:42 -UniFi =============plugin config Parameters========
23:19:42 -debugLevel []
23:19:42 -logFile /Library/Application Support/Perceptive Automation/Indigo 7.3/Logs/com.karlwachs.uniFiAP/plugin.log
23:19:42 -enableFINGSCAN False
23:19:42 -enableBroadCastEvents all
23:19:42 -ignoreNeighborForFing True
23:19:42 -expirationTime 120 [sec]
23:19:42 -sleep in main loop 4.0 [sec]
23:19:42 -use curl or request /usr/bin/curl
23:19:42 -cpu used since restart: 452:32.80
if not self.isValidIP(self.pluginPrefs[u"ip"+unicode(i)] ):
if not self.isValidIP(self.pluginPrefs[u"ipSW"+unicode(i)] ):
