- Posted on
Sun Mar 17, 2019 12:34 pm
roquej
offline
Matt,
Thos things:
1. Here is the sync report:
Z-Wave Syncing - started for "119 - Relay Power Switch"
Z-Wave Syncing - assigning return route to "119 - Relay Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Smart Switch 6 (ZW096) - 01030060
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 81v1 25v1 26v2 27v1 32v3 70v1 72v1 73v1 5Ev1 59v1 7Av1 85v1 86v1 33v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 20 "Power up state" is 0 "Last State"
Z-Wave Syncing - retrieved parameter 81 "LED mode" is 0 "Mirrors Load"
Z-Wave Syncing - retrieved parameter 3 "Current overload protection" is true
Z-Wave Syncing - retrieved parameter 83 "LED RGB nightlight" is 1774619
Z-Wave Syncing - retrieved parameter 84 "LED RGB load brightness" is 3289650
Z-Wave Syncing - retrieved parameter 80 "Automatic notification" is 2
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 80 "Automatic notification" changed to 2 (was 2)
Z-Wave Syncing - retrieved parameter 90 "Enable energy change reports" is false
Z-Wave Syncing - retrieved parameter 91 "Report threshold watts" is 25 watts
Z-Wave Syncing - retrieved parameter 92 "Report threshold percentage" is 5 %
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 600 seconds
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 600 seconds
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 112 "Reporting interval2" changed to 600 seconds (was 600 seconds)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 600 seconds
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 113 "Reporting interval3" changed to 600 seconds (was 600 seconds)
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 12
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 101 "Group 1 flags" changed to 12 (was 12)
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 0
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 102 "Group 2 flags" changed to 0
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Syncing - device "119 - Relay Power Switch" parameter 103 "Group 3 flags" changed to 0
Z-Wave Syncing - synced server clock to module (21:17, Saturday)
Z-Wave Syncing - created device "Entertaiment Center (ZW096)"
Z-Wave Syncing - complete
Z-Wave sent "Entertaiment Center (ZW096)" status request
Z-Wave sent "Entertaiment Center (ZW096)" energy status request
Z-Wave received "Entertaiment Center (ZW096)" energy total to 362.437 kWh
Z-Wave received "Entertaiment Center (ZW096)" power load to 77.610 W
2. Just trying things, I saved the device to X10, in preparation to exclude and reinclude. Out of the blue, I changed it again back to z-wave and re-synched. Well, it fixed the problem.
I repeated to all devices that had the issues, the trick worked for all.
Hope this helps find the issue.
JP
