Webserver Image Load Error
Wed Dec 05, 2018 11:21 am
ckeyes888 offline
Had this fixed in 7.1 but just upgraded to 7.2 and it's back again.
The log is flooded with this error:
WebServer                       http://192.168.1.80:8000/++image?cameraNum=1&width=320&height=240 load error: HTTP Error 404: OK
I replaced this line, as before in the indigoreqhandler.py file,
cherrypy.server.indigoConn._RaiseServerError(imageUrl + " load error: " + str(err))
with
return u"couldn't load image"
but it still returns the above error. Maybe something has changed?
Carl
Wed Dec 05, 2018 12:30 pm
Re: Webserver Image Load Error
Can you point us to the original post that had the instructions to edit that file? Context would help... ;)
[MODERATOR NOTE] moved to a more appropriate forum.
Wed Dec 05, 2018 1:02 pm
ckeyes888 offline
Thanks, I believe it was this one: viewtopic.php?f=83&t=14651
Carl
Wed Dec 05, 2018 3:35 pm
Did you restart the Indigo Server? I don't know why the patch you did before wouldn't work the same in 7.2.
Wed Dec 05, 2018 3:46 pm
ckeyes888 offline
Yes, I restarted a couple times. Just to be sure, it is the indigoreqhandler.py file right that needs the edit?
Carl
Wed Dec 05, 2018 4:58 pm
Yes. Are you editing the one in the Indigo 7.2/IndigoWebServer/ folder? Change lines 464 and 466 to both:
Wed Dec 05, 2018 5:41 pm
ckeyes888 offline
As always...Doh! Didn’t realize the upgrade made a new 7.2 folder with a new set of files.
Did the patch on the file in the 7.2 folder and all is well.
Sorry, thanks.
Carl
