using indigo logger in imported class
Mon Dec 03, 2018 1:07 am
trying to use indigo debug logger in an imported class.
this works:
import logging
   def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
   def startup(self):
      indigo.server.log("myLogSet doing logging stuff")
      logformatLOG = logging.Formatter('%(msg)s')
      self.indigo_log_handler.setFormatter(logformatLOG)
      self.indigo_log_handler.setLevel(logging.WARNING)
      logformatFile = logging.Formatter( '%(asctime)s.%(msecs)03d\t%(levelname)-12s\t%(name)s.%(funcName)-25s %(msg)s' , datefmt='%H:%M:%S')
      self.plugin_file_handler.setFormatter(logformatFile)
      self.plugin_file_handler.setLevel(logging.THREADDEBUG)
      self.mylogger = logging.getLogger("minMax")
      self.mylogger.info("info")
      self.mylogger.warning("warning")
      self.mylogger.error("error")
      indigo.server.log("myLogSet end  logging stuff")
this does not work :
import indigo
# import logging
class MLX():
   def __init__(self):
      return
   def myLogSet(self, **kwargs ):
      for key, value in kwargs.iteritems():
         elif key == "pluginSelf" :
            self.plugin         = value
         elif key == "logging":
            self.logging      = value
      self.plugin.indigo_log_handler.setFormatter(logformatLOG)
      self.plugin.indigo_log_handler.setLevel(logging.WARNING)
      self.plugin.plugin_file_handler.setFormatter(logformatFile)      # w date time ...
      self.plugin.plugin_file_handler.setLevel(logging.THREADDEBUG)
      return
and in plugin.py
import myLogPgms.myLogPgms
import logging
   def startup(self):
      self.ML = myLogPgms.myLogPgms.MLX()
      self.ML.myLogSet(pluginSelf=self, logging=logging)
the self.mylogger statements do nothing, no output, no error.
Question: how do I use the indigo debug logger in an imported class.
tried all kinds of variations w local logger import, handed down from indigo ...import indigo in imported file ...
have looked at other plugins ..
any pointer is welcome.
Mon Dec 03, 2018 10:24 am
Re: using indigo logger in imported class
In your startup call, you're passing the logging module. I think what you want to do it pass the logger (self.logger):
   def startup(self):
      self.ML.myLogSet(pluginSelf=self, logging=logging) # should be self.logger since that's the logger instance created for the plugin
But there are a other potential issues in your MLX class. I think before trying to identify everything that's wrong there, maybe we should get a description (not code) of exactly what you're trying to accomplish from your logging exactly. Can you just describe that and maybe we can help simplify this for you?
Mon Dec 03, 2018 2:25 pm
just found it after a long walk and a lunch w w:
correct:
         self.mylogger = logging.getLogger("Plugin.minMax")
does not work
would be nice to have a simple code section , like in the SKD package how to get started with the indigo logger
here my working code:
import logger
         self.plugin_file_handler.setFormatter(logformatFile)      # w date time ...
prints: to stand indigo log:
 minMax Warning                  warning
   minMax Error                    error
and to .../Logs/plugin id ../plugin.log
14:20:05.780   INFO           Plugin.minMax.myLogSet                  info
14:20:05.780   WARNING        Plugin.minMax.myLogSet                  warning
14:20:05.781   ERROR          Plugin.minMax.myLogSet                  error
Mon Dec 03, 2018 4:28 pm
I had my own debugging schema, with some logic with ifs/ error printouts, formatting / file management ...
Realizing that that does not work well with the indigo logger as it prints always the calling method / function. ... and that would always be the same :my logging method, not the method that calls the logging method..
Is all done in a one liner:
if self.ML.decideMyLog(u"Sql"): self.ML.myLog( errorType = u"bigErr", text =" msg here ", mType=" abc", showDate=True, destination="standard")
if SQL logging on, then print text to different log files depending on options, with prefix and w/wo date-stamp...
anyway will need to consider if switching adds anything, besides some learning
Is there a way to not print the current function but the preceding in indigo logger?
Mon Dec 03, 2018 5:18 pm
kw123 wrote:
does not work
Well, it did in fact work, it just created a new logger named "minMax" that wasn't in the plugin's logger chain so nothing showed up in the places you wanted.
We do need to add logging docs (other than what's in the Indigo 7.0 announcement thread).
Mon Dec 03, 2018 5:45 pm
Not sure I'm following - can you show me an example?
Mon Dec 03, 2018 6:28 pm
current setup:
in
   def pickDeviceCALLBACK(self,valuesDict="",typeId=""):
I call:
      if self.ML.decideMyLog(u"Setup"): self.ML.myLog( text= unicode(valuesDict), mType="pickDeviceCALLBACK" )
if Setup --> ON:
pickDeviceCALLBACK   unicode(valuesDict)
will be printed to a logfile.
with
logformatFile = logging.Formatter( '%(asctime)s\t%s%(funcName)-25s %(msg)s' , datefmt='%H:%M:%S')
When doing
def self.ML.myLog(text=""):
self.mylogger.info(text)
it will print
"time myLog text"
should do
"time pickDeviceCALLBACK text"
instead of myLog print the calling function pickDeviceCALLBACK.
I guess the logger has to be IN the function.. ... that prevents logic I would like to add
looking at the doc for logger thats likely not in the cards at least not that easily.
Anyway it works for me right now. will tackle it again when i have time.
thanks
Tue Dec 04, 2018 11:32 am
Right - wrapper methods around logging will most likely result in function names not working right (at least using the built-in log formatter). I'd recommending simplifying - lots of complexity in what you're doing and you'd likely do better just rethinking it in light of how the logger works.
Tue Dec 04, 2018 12:19 pm
These thing are historically grown
Problem is that I have > 2000 log statements with many little variations. So a simple change string will not work.
Was looking for a simple way to move a conversion to a method all my log actions go through currently.
